1998 12.7 series 60
Fan cuts on at 130 from fifteen seconds to several minutes then off. Continues this behavior 140. 150. 160 etc.
what's going on? I was under impression 190 is when fan should kick on. ..
What should i test. I don't wanna burn out my fan clutch or burn fuel money! Help!
detroit fan on early?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by HellStomper116, May 1, 2015.
any codes? sounds like it could be a ground wire connection.
Don't see any codes. .. but the display don't work either :/
I'll check the for grounding problems. Thanks. Have to get to a shop and read the codes -
Could be the a/c high pressure switch.
How would that have affect on the fan?
Your ac system can tell your fan to turn on just like your cooling system.
HellStomper116 Thanks this.
