This was on the magnet of drain plug after oil change. It was posted to my fb feed. Guy doesn't know what it is.
anybody have a clue.
Detroit internal motor part ID needed. Name this part.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by blanco, Dec 5, 2013.
can you place a penny next to it in a picture for scale?
What model of detroit is it from 60 series? And is the engine running smooth? First thing that comes to mind is it some type of valve spring washer or a injector component? Whats the engine history could it be a left over from a previous repair or failure that was lost in head and worked its way over time into crankcase? I am very curious as to what it is aswell.
My best guess is head bolt washer.
Wait!! maby its not a broken part but some sort of a C washer
http://t3.gstatic.com/images?q=tbn:ANd9GcStOVoJLf7Qj31kt5u1wBgqO2qhmeM66PKXiYoPSlrZO1LIxv5yKQ like this. is it sheared at each end or does it look machined to that shape? -
http://www.jacobsvehiclesystems.com/files/support/docs-pdfs/29901B.pdf Figure 20 washer 18. Had a lot of my 00-01's break.
If that is the peice then it is missing the other peice of it. Does it look broken.
It doesn't look like anything that is part of piston or valve. I wouldn't worry just take valve cover off and look for that peice on the top of jake. If it was part of valve you would have dropped a valve by now.
