Detroit s60 DDEC VI EGR issue.
Discussion in 'Experienced Truckers' Advice' started by LoneRanger, Aug 10, 2018.
  1. LoneRanger
    LoneRanger Road Train Member
    3,687
    9,584
    Jun 3, 2018
    I have a 08 Columbia with a S60 DDEC VI, the barometric pressure sensor is in the ECM, and can’t be bypassed with the resistor.
    Is there a kit for this? I see DD15 kits but not a S60 DDEC VI delete kits.
    Any help would be appreciated.
  3. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,541
    May 22, 2017
    Do you mean barometric pressure sensor?
    LoneRanger Thanks this.
  4. LoneRanger
    3,687
    9,584
    Jun 3, 2018
    Made the change, thanks for catching that.
  5. Oldironfan
    5,776
    5,541
    May 22, 2017
    It's in the ecm on ddec 6??
  6. LoneRanger
    3,687
    9,584
    Jun 3, 2018
    That’s what Detroit Diesel Said and we checked all over. No sensor anywhere near the intake manifold or wiring harness.
    So we are stuck trying to figure out why the truck is sputtering while the egr plugged in and runs fine when not plugged in.
    Decided to bypass egr with resistors but found out it’s a DDEC 6.
  7. Oldironfan
    5,776
    5,541
    May 22, 2017
    Is your engine a 12.7 or 14?
    Do you have a flat air filter?
  8. LoneRanger
    3,687
    9,584
    Jun 3, 2018
    Round air filter, 14L
  9. Oldironfan
    5,776
    5,541
    May 22, 2017
    I don't think you have a ddec 6. Is your ecm silver. I think you have a ddec v.
    Ddec 5, should have a baro sensor at the back of intake manifold, on the bottom of it. Follow the hotness. It is a flat black square, unhook it, for the resistor trick for high alt mode.
    25(2)+2 Thanks this.
  10. LoneRanger
    3,687
    9,584
    Jun 3, 2018
    Nope not there,
    Here’s a funny thing I found.
    Info on visor says 475 hp but engine stamp says 515hp
    Detroit Diesel said the SN on the engine is for a DDEC6
  11. Oldironfan
    5,776
    5,541
    May 22, 2017
    Can you get pic of the ecm.
