Hi guys I need some help from experience people ,so my story is my friend is a good mechanic and we (me helping him) got overhaul done on Detroit S60 (ddec5) engine . We did whole nine yards reman head, new main bearings ,new oil pump ,counterbores cut , new injector harness ,new 6 pack of Injectors , same cam shaft (was ok). When we started the truck it was smoking little bit but not a lot and then it starts misfiring we connected laptop and on cylinder 6 and cylinder 3 respond time dropped to 0.3 when all others where 0.83, and its smoking little bit . So after reading over this Forum i have couple things in mind ,1 injectors from Detroit came bad , 2 Injector Harness ,3 sensor harness ,4 OEM harness,5 bad Valve adjustments ,6 bad timing missed one tooth . I would really appreciate all hints and help .Thanks this forum for all the information it provides
Detroit S60 (DDEC5) problems after overhaul
Discussion in 'Freightliner Forum' started by iuriikyryk, Mar 14, 2019.
#2,#5 and #6 sound possible. Easiest thing to check first is timing. Pin cam and crank properly. Also you did not mention injector adjustment. 40 in/lb. is proper value.
We've had to go back and reset the timing before, also the valve adjustment could be off. I'd check all clearances front to rear.
