Detroit Series 60 Fan On Constantly
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brewart12, Jun 25, 2020.
  1. Brewart12
    Brewart12 Bobtail Member
    Hey everyone brand new to the site.
    I have a detroit series 60 12.7 L in a 2001 Fire Truck and the fan is constantly on.
    It doesnt appear to be controlled by an air solenoid its hooked directly into the belts if that makes sense.
    Is this type of setup suppose to stay on constantly or cycle on and off ?
    Thank you
  3. bad-luck
    bad-luck Road Train Member
    3,300
    6,064
    Nov 16, 2013
    Baltimore, Maryland
    Usually the fans are either air or electronically operated. It is possible, that the fan on the truck, is set to run all the time, because of the short runs, and the excessive idling, when pumping if it is an engine. Do you have any pix?
    Rideandrepair Thanks this.
  4. bad-luck
    3,300
    6,064
    Nov 16, 2013
    Baltimore, Maryland
    Forgot to welcome you here!
  5. Rideandrepair
    17,337
    56,256
    Aug 8, 2015
    If there’s a 1/4” air line running into the fan, it comes from the selinoid. You’ll also see the 2 disk clutch itself, behind the belts. If it’s a clutch type fan.
    lwlevens Thanks this.
