Detroit Turbo Not Spooling??
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OldeSkool, Feb 17, 2020.
  1. OldeSkool
    OldeSkool Road Train Member
    1,901
    5,859
    Jul 17, 2018
    New Hampshire
    I have a 07 Freightliner Century 14 liter Detroit EGR deleted. This truck has been running rough occasionally lately, but has definately gotten worse now.
    Especially I notice on take off, but even when just driving down the road the truck will sputter around erratically. I thought I got bad fuel, and dumped lucas injector cleaner in the tank. It continued doing it, so next tank I dumped some Howes Diesel Treat in it thinking maybe I had water in the fuel. I also drained my fuel filter and it shows to be fine. (Less than halfway up the filter in the clear housing.)
    Now while going down the road it would not get above 1,200 RPM's in 10th gear so I downshifted to 9th and it won't get above 1,500 RPM's. It kind of sputters a bit but I noticed my turbo is not spooling up. I'm wondering now if a sensor or turbo could possibly be going bad. I recently replaced the turbo pressure sensor on the intake manifold for a similar issue. Yes its a genuine Freightliner part.
    Does anyone have any ideas if it could possibly be turbo related or fuel or none of the above? At first I thought possibly injectors, but its not throwing any codes.
  3. truckdriver31
    6,998
    8,360
    Sep 18, 2013
    did you look at the fins
    OldeSkool Thanks this.
  4. OldeSkool
    1,901
    5,859
    Jul 17, 2018
    New Hampshire
    Several months ago but not recently.
    truckdriver31 Thanks this.
  5. AModelCat
    161,606
    VGT turbo or did you switch it out for an aftermarket?
  6. OldeSkool
    1,901
    5,859
    Jul 17, 2018
    New Hampshire
    Its a factory turbo. I think it's definately something turbo related. I'm thinking that turbo pressure sensor again possibly, because I shut it off and restarted it and the turbo spools up fine for a while.
    Rideandrepair Thanks this.
  7. truckdriver31
    6,998
    8,360
    Sep 18, 2013
    you still got vpod etc
    BoxCarKidd Thanks this.
  8. Hulld
    Hulld Road Train Member
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    Sounds like it could be a vpod sticking issue.
    Mine screws up once in a while when it’s really cold.
    Does it blow smoke when it’s running poorly?
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    No fuel no turbo spool.
    Bad inputs to the ECM can cause no fuel.
    They have a shaft on the front with two gears side by side. If the key is half mucked up it can cause timing sensor errors. When you shift, jake or shut it off a gear can move on the shaft. Then run well for awhile.
    Not saying that is your problem just sharing. You need a knowledgeable person with good software. If you often have SRS, TRS and or timing point errors I would suspect it.
  10. Hulld
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    Turbo also won’t spool if the VPOD sticks and VGT turbo vanes are held in the closed position.
    Like a potato up the tail pipe...
    Engine rpms also drop quicker between shifts when this occurs because of all the exhaust back pressure in the engine.
  11. Hulld
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    07 14.0 liter stock VGT turbo uses a VPOD.
    EGR can be deleted and still maintain the integrity of the stock VGT turbo.
