Diagnostic help please?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hedon, Jul 30, 2012.
  1. Hedon
    Hedon Light Load Member
    121
    95
    Jun 29, 2009
    SW Missouri
    Ordinarily I figure out what is causing the current problem on the truck by the simple solution that the bad part must be the most expensive part on the truck that hasn't been replaced in the last six months. You'd be surprised how often this method seems to work for me. :biggrin_25512:
    This time though I think I could use some help. I have many tiny little specks of what looks like oil on the tractor that look like they must have shot out the pipes and then rained downward. Don't really see any smoke while moving. Everything else seems to be ok.
    According to my usual method of diagnosing the problem it should be the transmission as that is the most expensive thing not recently replaced. Unless it is the engine itself of course. But I can't see the tranny raining oil down on me.
    Anyone have any ideas? I would appreciate the help.
  3. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    first off, do you covers over the pipes? and if no, did it rain recently?
    last 1 Thanks this.
  4. Hedon
    121
    95
    Jun 29, 2009
    SW Missouri
    There are covers over the pipes. But I'm not sure how solidly they cover them so there are probably gaps. And I have been in some terrible rain storms recently -- every day for six days. I keep hearing there's a drought but you couldn't prove it by my routes recently.
  5. -insert name-
    -insert name- ATM squishier
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    Possible pictures of the specks? Or more details on where they are? As for now, put five bottles of stop leak in it with your oil.
  6. snowwy
    snowwy Road Train Member
    20,594
    13,315
    Jul 6, 2009
    what kind of stop leak. cuz i need that for my isx. till i get 3g to fix the cover
  7. -insert name-
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    Not sure, never had a problem like this.
  8. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
  9. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    Look in turbo at waste gate. Do you see oil dripping or appears to be spraying out? If so, oil line gasket is bad causing droplets of oil to mix with exhaust. $2 part to fix. ISX engines do it a lot
  10. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    Rain falling into your stacks while parked with the engine off will be blown back out when you start up as black soot that you will see as spots on any flat painted surface. And it can come from the truck parked beside you too.
  11. Hedon
    121
    95
    Jun 29, 2009
    SW Missouri
    Thanks guys! I'll check out the turbo and hope it was just the rain.
