Did I mess up my slack adjusters?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Fld303, May 26, 2019.
  1. Fld303
    Fld303 Bobtail Member
    11
    5
    Apr 21, 2019
    i have automatic adjusters and I totally forgot that I had to pull out a pin in order to turn the adjusting hex bolt. Anyways I tightened it very much without pulling the pin. Then when I remembered I had to pull the pin, it was very very hard to losen it. I finally adjusted it properly, but might of done internal damage to the slack adjuster?
    Thanks guys
  3. Omega1
    Omega1 Heavy Load Member
    721
    1,598
    Nov 18, 2017
    Oregon
    Just wow! That's all I can contribute.
    Heavyd Thanks this.
  4. Fld303
    11
    5
    Apr 21, 2019
    Serious replies please
  5. Rideandrepair
    17,424
    56,529
    Aug 8, 2015
    Usually only have to raise pin up to back them off. You did it right
    Cam Roberts Thanks this.
  6. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    The thing about auto slacks is they are designed to stay in adjustment by themselves if operating properly.
    1-3 full depressions of the pedal stroke keeps them adjusted to correct stroke lengths WITHOUT manual adjustment.
    If they are not automatically adjusting, and you are forced to do it manually, it is but a SHORT TERM fix.
    They will adjust right back out of whack with travel.
    Keep an eye on it. May have to replace it.
    magoo68, Rideandrepair and Cam Roberts Thank this.
  7. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    No worries, Sounds like you over tightened them and had difficulty backing them off. You did the procedure right. NExt time just tighten them without going crazy. I just replaced every single slack adjuster on my truck with haldex aut slack adjusters without the pull up pin and have a ratchet effect. I did so becuase i had a few that kept going out of adjustment. Like someone else that posted, Once you install them, they never need adjustment unless they are wore out. When you do brakes, obviously you have to back them off to get drum off.
    Maybe you did your brakes but if not, and they went out of adjustment, just put new ones on. They are inexpensive when it comes to safety and easy to install
    Rideandrepair and skellr Thank this.
  8. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Thats all the reply some of these company drivers can give becuase they dont work on trucks. They drive for companies
  9. AModelCat
    161,298
    And then throw some BS line about being certified or something.
  10. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    You only need to pull the pin to loosen it. As long as you could still pull the pin ( it wasn't bent internally) I think it's going to be fine.
  11. Dave_in_AZ
    411,353
    Here ya go bud.
    $78 from Snap On.
    I run the west, PNW, Rockies.
    You need to check and adjust, believe me.
    Comes with instructions.
