Diesal fuel bypass!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by guru23231, May 21, 2014.
  1. guru23231
    guru23231 Light Load Member
    53
    Sep 27, 2013
    Seattle, WA
    I got a 2005 detriot series 60 14.l. I just bypassed my fuel, so it's no loner connected to fuel water sperator system . Is it safe to run it like this ? I do have a secondry fuel filter .
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    No, It has a primary filter with water separation capability for a reason. if water gets past the secondary and that filter is not made to stop water it will destroy the injectors and if it blows the tip completely off can destroy you turbo and with no tip the injector will pound in an extreme amount of fuel. It will destroy the cylinder kit.
    Other than that go for it!
    Just a thought!
    guru23231 Thanks this.
  4. nightgunner
    nightgunner Road Train Member
    2,112
    2,800
    Jul 23, 2013
    Cedar Rapids, IA
    Those are just extra parts that Detroit puts on to charge you more money. .
    Seriously bad idea.
  5. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    How did you mastermind this plan? Conspiracy theories on the CB about fuel filters stealing the lubricity from the fuel? Better MPG with no filters?
    This was a TERRIBLE idea. Dangit boy!
  6. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    why would you do this exept maybe to get the truck off the road other than that its kinda retarded
  7. tom b
    tom b Bobtail Member
    28
    5
    Feb 2, 2011
    cottonwood mn
    my FASS pump died one night.... I got the bright idea to bypass it... only 180 miles home... 2 dead injectors by the time I got home...wasn't worth it
    guru23231 and baha Thank this.
  8. guru23231
    53
    Sep 27, 2013
    Seattle, WA
    I did it because freightliner dealership broke my filter cap and I couldn't wait for another one. Freightliner said it safe till I get filter cap. Cuz I have a secondry fuel filter.
  9. freightlinerman
    1,287
    536
    Mar 4, 2011
    Florida
    You do realize that you can put a spin on filter on the Davco temporarily to? This way, you wouldn't have to disconnect anything.
  10. blackcrowntrans
    blackcrowntrans Light Load Member
    133
    73
    May 19, 2014
    You'll just have to change the filter more often I never liked those water separators they break to much
  11. freightlinerman
    1,287
    536
    Mar 4, 2011
    Florida
    How do they break? It is a simple design, a globe with o-rings and a check valve. If you over torque the plastic base you can crack things.
