Diesel Exhaust Fluid Poor Quality Warning alert. What to do?
Discussion in 'Experienced Truckers' Advice' started by freightwipper, Feb 28, 2015.
  1. freightwipper
    freightwipper Road Train Member
    9,366
    11,439
    Mar 24, 2014
    OTR
    So I just filled up DEF at a Pilot and within 20 minutes of driving I got this alert pop up, along with a check engine light.
    It's a 2015 Kenworth T-680.
    Any advice would be appreciated.
    BillStep Thanks this.
  3. freightwipper
    9,366
    11,439
    Mar 24, 2014
    OTR
    It says to replace with new DEF but I can't really do that with a full tank.
    Can't find anything in the owners manual.
  4. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Hold seller accountable ......?
    I foresee a trip to a dealership ...
    To be fair the def could be ok.. It might be a sensor/ wiring issue...,I'd head towards help. OC or dealer.
    Grubby, Lepton1 and freightwipper Thank this.
  5. RetiredUSN
    RetiredUSN Medium Load Member
    694
    991
    Jan 9, 2015
    Is it slushing up?
    I have been doing a little reading lately and found that some of the truck stop brands of DEF can slush easier than others.
  6. freightwipper
    9,366
    11,439
    Mar 24, 2014
    OTR
    I haven't noticed any changes in driving the truck.
    I called a dealer and asked what his advice would be...
    He said "where did you get the DEF from" I said at a Pilot in Ohio.. he said "that was your mistake right there" (without giving any further explanation)
    Then told me I should go to a dealer to get it drained.
    I was hoping to avoid going to a dealer over DEF fluid ugh.
    Any idea how I can go after Pilot for selling garbage DEF?
  7. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    It might not be the def... You never know with the new trucks what the real problem is/was....
    The longer you drive the more the ECM will derate the motor.....
    P.S. If it was the def every truck that got def at that pilot would be throwing a code....
    86scotty and Rolling18 Thank this.
  8. freightwipper
    9,366
    11,439
    Mar 24, 2014
    OTR
    I would consider that a possibility BUT this happened within 20 minutes of filling up with DEF. I find that timing too much to be a coincidence
    Cat sdp Thanks this.
  9. david123abc
    david123abc Heavy Load Member
    839
    784
    Feb 2, 2011
    Augusta, GA
    Since urea freezes at a higher temperature than water, could you have basically pumped water into the tank?
  10. freightwipper
    9,366
    11,439
    Mar 24, 2014
    OTR
    I'm going to a kenworth dealer tomorrow nearby and stop driving. Didn't want it to come to that but I'm not gonna take any chances...
    Whenever I take chances I get :smt075
    RetiredUSN and Cat sdp Thank this.
  11. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Best choice , I wish you luck..... I'm going to guess they'll drain the def and replace. And the problem will persist and in the end it will be a sensor or heater for the tank or line......
