diesel freaks- any comments
Discussion in 'Trucks [ Eighteen Wheelers ]' started by slowhandpete, Jun 18, 2011.
  1. slowhandpete
    slowhandpete Bobtail Member
    48
    12
    Jun 18, 2011
    salem,in
    has anyone besides me tried a product from diesel freaks. the product you install in between the turbo boost sensor harness and the fuel temp sensor harness, looking for comments especially from you Mr. Haney
  3. dr1c
    dr1c Light Load Member
    75
    11
    Apr 10, 2011
    Alberta
    I would assume It's the same as www.performanceharness.com They sell the same thing or build your own! Search caterpillar power harness on this board for lots of info
  4. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
  5. truckmaster9400
    truckmaster9400 Bobtail Member
    24
    7
    Nov 13, 2010
    Crawford, Al
    i tried them on my c-13 they make a reliable product didnt see a real big fuel economy increase but did gain in power,i had both products.
  6. Pete3896nz
    Pete3896nz Bobtail Member
    11
    Jun 13, 2016
    Ran one trip with the harness on stock 550 c15 boost pressure went up about 10lbs and the gauge always reads that it's getting boost even going down hill definitely better throttle and quicker response as far as fuel goes to soon to know if you floor it you will get black smoke if you are gentle with the pedal you won't get any
  7. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    A boost sensor mod does nothing for overall performance, you will have slightly better low end response but once turbos make boost it is useless.
    Fuel temp gains are seasonal, doesn't work when the fuel warms up.
  8. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    I have them both, don't do it for fuel economy, a little better response and the boost wire, I have the one with the switch so I can use it when and how I wanted, and control the smoke with it, expensive but reliable so far it's been about 2 years and still working good.
    I probably feel the fuel wire hp better than most because I have a very efficient fuel cooler, but the best performance it's still in the morning when the fuel is as cold as it can be.
  9. mitrucker
    mitrucker Road Train Member
    5,147
    8,821
    Dec 15, 2010
    Lapeer, MI
    What is the big deal with the thick black smoke out of the stacks? Seems silly to waste fuel on something so trivial.
  10. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    Any info on that cooler, link or brand?
  11. T800H
    608
    295
    Apr 2, 2010
    The Keys
    lets see if this works, https://www.aliexpress.com/item/Tan...1365293223.html?spm=2114.40010308.4.65.wCxpYb
    I didn't buy it from this guys but is the same cooler, since I got a totally different radiator I had to re arrange the cooler, so it wasn't cooling like it did before that, then I cut some of the bumper and is a little better, but I'm going to order a rectangular one much longer and than order a custom bumper to fit the new cooler and that should make me a happy camper again, I saw a difference of 30 to 40 degree from the original 18 year old depleted one and that's why I want the bigger one with the new bumper, South Florida is very hot during the summer.
    Oxbow and Luwi67 Thank this.
