diff lock indicator
Discussion in 'International Forum' started by muff, Jul 2, 2014.
  1. muff
    muff Light Load Member
    73
    38
    Dec 20, 2010
    ontario,Can
    2005 9400i how do go about fixing the diff light indcator on the barnyard cadilac . changed the bulb but still no go . any ideas ?
    Thanks Muff
  3. bad-luck
    bad-luck Road Train Member
    3,300
    6,064
    Nov 16, 2013
    Baltimore, Maryland
    If you replaced the light and it is still out. Check the wires and sending unit on the transfer case on the front rear
  4. muff
    73
    38
    Dec 20, 2010
    ontario,Can
    only sending unit on diff I seen was for temp. how do I know ? simple it didn`t work either so I found a new harness and installed it now the temp works . Don`t tell the mechanic ...lol
  5. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    That circuit is protected by a fuse or breaker in the fuse panel in front of the passenger seat. Located in F4-A, should be 10 amp. Make sure it isn't popped or blown. Then like bad-luck said, there is a mechanical switch on the diff itself with a two wire connector. With the key on you should have power at one of the pins.
  6. muff
    73
    38
    Dec 20, 2010
    ontario,Can
    ok Thanks Heavyd. I will check the breaker tomorrow. like I said earlier I changed a wiring harness go to front diff and the diff temp gauge started to work . Any chance it would operate both circuits ?
    on a different topic is there an easy way to change the cab/sleeper shocks . the only good one let go today . old trucks ....lots of work .
  7. Heavyd
    7,773
    6,211
    Feb 4, 2009
    I see the diff temp and the diff warning are powered by the same breaker/fuse, but splits off to individual circuits in the dash. Different grounds too.
    muff Thanks this.
