Difference between 1650 torque and 2050 torque clutch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hulld, May 27, 2018.
  1. Hulld
    Hulld Road Train Member
    2,883
    6,566
    Oct 19, 2015
    Upstate NY
    I was wondering what the the physical difference is between lower torque capacity to high torque capacity clutchs ?
    Is it just all in the disc design or do the high capacity set ups have heavier spring pressure plates with more clamp load ?
  3. otterinthewater
    5,535
    29,096
    May 10, 2018
    Santa Barbara, Ca
    Hulld Thanks this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    Originally I was gonna say 4pad vs 6pad. After looking clearly that is not the only difference. My guess is the right combination of both.
    black_dog106, Dino soar and Hulld Thank this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,463
    6,504
    Aug 26, 2014
    If you are stepping up just be sure the clutch hub will fit in the flywheel.
    Vampire, Hulld and wore out Thank this.
  6. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    I think damper and pressure plate springs are different. A 1650 usually has a 4pad disc and higher ratings an 6 pad.
    Hulld Thanks this.
  7. Hulld
    2,883
    6,566
    Oct 19, 2015
    Upstate NY
    I am looking at stepping up to a higher rated capacity clutch because with the tune I’m running in my 14 liter ddec 5 series 60 I can slip the clutch on a hill when I’m in high gear.
    It only slips when I am loaded and on a long hill and I tip in the throttle in high gear and the boost shoots up to 45 or 50#s and then she cuts loose.
  8. Hulld
    2,883
    6,566
    Oct 19, 2015
    Upstate NY
    The clutch that’s in there is a 1650 easy pedal but I think it’s a six pad.
    That’s why I was wondering where the higher capacity clutch’s get there holding power from?
  9. skellr
    skellr Road Train Member
    8,737
    12,185
    Jul 17, 2011
    The Village, Portmeirion
    Wrong thread...
  10. MACK E-6
    48,703
    224,684
    That’s scary. Does it still hold you in lower gears on a downgrade?
  11. Hulld
    2,883
    6,566
    Oct 19, 2015
    Upstate NY
    Yes holds perfectly down hill fully loaded and full Jake on.
