Differences between Dry van and Reefer?
Discussion in 'Questions From New Drivers' started by DevJohnson, Dec 13, 2017.
  1. DevJohnson
    DevJohnson Medium Load Member
    340
    153
    Nov 27, 2017
    i don’t believe there are too many differences other than setting the temp and gassing up more than usual correct? Don’t you have to get the load to the shipper by a certain time so your load doesn’t expire?
    Steel Dragon Thanks this.
  3. Steel Tiger
    Steel Tiger Road Train Member
    2,665
    3,221
    Jun 6, 2012
    Orlando, FL
    This ought to be good.:happy1:
    Vic Firth, HotH2o, Kyle G. and 3 others Thank this.
  4. chmpbt
    chmpbt Bobtail Member
    31
    13
    Sep 12, 2017
    One is cold, one isn’t cold.
  5. Chinatown
    Chinatown Road Train Member
    74,664
    169,669
    Aug 28, 2011
    Henderson, NV & Orient
    Lot more responsibilty with reefers. Usually lots of night driving and appointment times in the wee hours. Sure, have to monitor the temperature and insure the reefer fuel tank always has plenty of fuel. I never let the reefer fuel tank get below 1/2 and will top it off whenever I fuel the truck.
    Did you choose a company yet?
    Toomanybikes and Steel Dragon Thank this.
  6. SHOJim
    SHOJim Road Train Member
    3,399
    17,210
    Apr 19, 2011
    Columbus, Ohio
    Sit in a dry van and smoke reefer, best of both worlds...
    HotH2o and Steel Dragon Thank this.
  7. QuietStorm
    QuietStorm Heavy Load Member
    899
    1,416
    Dec 11, 2016
    Odd delivery times around the clock, lots of driving low on fuel because they load you as close to gross as possible, sometimes getting unloaded or loaded can satisfy your 10 hour break requirement.
    Other than that, it's the tits.
  8. QuietStorm
    899
    1,416
    Dec 11, 2016
    Annnnd learn to sleep with the noise.
  9. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    Reefer is only good in a bong.
    Advantages to dry van?
    Lots of drop and hook.
    Lots of light loads.
    Quick loading and unloading,usually one hour tops.
    No truck washes unless your pimpin.
    Shippers receivers are actually glad to see you.
    No lumper fees.
    Other truckers don't hate parking next to you.
    Pay is the same.
    Toomanybikes and SHOJim Thank this.
  10. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Except in the winter up north.
  11. Kyle G.
    Kyle G. Road Train Member
    3,840
    20,148
    Jan 23, 2016
    Eastern Iowa
    I had a short stint on a wisconsin regional position during my time at roehl. It was mostly reefer, and it was awful. Now it may be better at other companies that are strictly reefer, but in my experience, on top of the regular headaches like long unloads, crazy appointment times, etc., it seemed like every time i hooked up to a new trailer, it was filthy inside and/or almost out of fuel. Totally wasn’t worth the few extra cents per mile in my opinion. I will never touch another reefer.
    Steel Dragon and freightwipper Thank this.
