differences between US and EU trailer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 98989, Nov 10, 2011.
  1. 98989
    98989 Road Train Member
    5,990
    6,740
    Sep 14, 2008
    hello guys i have some questions for you related to your trailers...
    so first of them is why you use mostly only van trailers
    here van trailers are very very rare, also flatbed are rare( some people use flatbed but with sideboards)
    most of people use curtainsider trailer
    you can load from sides from top and from rear
    also it is sometimes possible to load containers below tarpaulin you can load everything what you want
    also they are lighter than van trailers
    more flexible and this made them more comfortable behind trucks (van is too rigid)
  3. 98989
    5,990
    6,740
    Sep 14, 2008
    [ame]http://www.youtube.com/watch?v=CtSN9-XYTkM[/ame]
    [ame]http://www.youtube.com/watch?v=T1P0btX9k3A&feature=related[/ame]
  4. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    How do you haul refrigerated product?
  5. 98989
    5,990
    6,740
    Sep 14, 2008
    same as in us . But also there are some curtainsider reffers.or van trailers with side doors
  6. U2Exit
    U2Exit Road Train Member
    2,353
    1,051
    Feb 22, 2008
    WA and VA
    yep, when I was in Germany last month I saw a couple curtain side reefers. I cant recall seeing one flatbed similiar to what we use in the US.
    I maybe saw one or two reefer trailers that appeared to have any sort of significant insulation type walls.
    Not very much fun to check out the trucks while on the Autobahn... When 99 percent seemed to be curtain side trailers, I lost interest real quick on a four hour ride to Munich. I loved the countryside views.
    Even less interest looking at trucks while nursing a hangover on the ride back after a full day of experiencing Oktoberfest:biggrin_2552:
  7. Scania man
    Scania man Road Train Member
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    There are some Multipurpose trailers here too, like a machine carrier lowloader/curtainsider, it's a lowloader with a curtainsider body, used for dry palletised freight or can carry large excavators etc, the roof opens, lifts up and the pillars can be hydraulically widened out up to 3 feet either side to facilitate loading or just to fit very large machines, Alot of Nordic countries use reefers with side loading, also walking floor trailers are replacing tippers cos they can carry bulk or can be used for palletised freight just like a box trailer and also don't have the risk of roll over like a tipper. I parked beside a us army box trailer in Germany last night, they are Alot narrower and lower than ours, it was pulled by a us army registered scania r380 and it was 2 inches narrower ( approx ) on either side, side by side pallets must be very tight inside!
  8. Scania man
    2,199
    483
    Jul 1, 2011
    Saskatchewan
  9. Scania man
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    Steering axles don't appear to be common in the US either
  10. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    not all the difference.
    EU trailers are now all with EBS and disk brakes. In the USA EBS is the option and really rare option. Newer EBS units, including the last EBS-D, all the EBS-E by Wabco and TEBS-2 by Knorr/Bendix got RSS - roll stablity system. ECAS is very rare thing on EU trailer now.
    The last Wabco TEBS-E unit is not made in US and EU versions, it may easily be programmed for 12V and 24V voltage supply, so I can easily use it with US trailers and trucktors. It is really good.
    Axes... BPW, SAF(Holland) and Meritor (ROR) are with disk brakes. Drum brakes are available too.
    Lenth of EU trailer is usually 45', but shorter (40') and longer 48'-55' are used, but generally EU trailers are 45'.
    Weight distribution differs too. ~10 500 per fifth wheel. three axels with single 385/80R22.5 tires. Lift axels are popular.
    Air systems of EU and US trailers are compatible. Kingpins too. So you can easily use US trailer with EU truck and EU trailer with US trucktor. The only problem - change bulbs and use voltage converters for ABS/EBS systems.
    One good thing of US trailers - axe slider, but this thing is for good roads. If I have to haul from EU to Russia I run over bad rought roads and slider goes bad!!!!
    Tailamps of EU trailer are with yellow direction lamps, US trailers dir. lamps are red. really..... I cant concider it problem!
    If we use US made trailers on European roads we have to add side guard that prevents car under trailer accident, and IMO it saved many lives.
    Later I gonna post some pics of US trailers with European side guards.
    Scania man Thanks this.
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Ouh, there is tought steel frame of two rails under EU trailer and usually plywood floor.
