Different tires for my drop axle?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rick Wilmath, Jun 21, 2018.
  1. Rick Wilmath
    Rick Wilmath Light Load Member
    57
    May 15, 2016
    I have a 93 Freightliner truck. I added a drop axle a few months ago and it is working out real well.
    However, the tires need to be changed and I would like to get used tires if I could. The wrecking yard didn't have the size I needed (255/70R 22.5) so I was wondering if I could install a more common 22.5 on them.
    The other wheels on the truck are 24.5 and there is plenty of clearance when the axle is up in the air.
    Thanks
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    As long as they clear the fenders and what not you sure can change them. Might have to readjust the pressure a little so its not loading the tires with to much weight.
  4. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,292
    Sep 12, 2017
    Plymouth MI
    Throw a set of Chineseium tires on, that is what I use on mine. Good old Double Coins.
