Differential lock do i have to stop when use.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by joe016, Jan 23, 2016.
  1. joe016
    joe016 Light Load Member
    120
    29
    Jan 23, 2016
    i have a 2005 freightliner m2 with the mbe 4000 10 speed heavy duty when i buy the truck i did not get a manual i would like to know when i engage and disengage the differential lock do i have to come to a stop i would like to know for sure i haul side dump so i go off road alot .
  3. AModelCat
    155,070
    As long as you aren't spinning wheels or driving at highway speeds you should be fine engaging/disengaging them while moving.
  4. truckdad
    truckdad Road Train Member
    2,021
    16,631
    Dec 14, 2014
    Penn Valley, CA
    But if you spin out & come to a stop, do NOT engage if a wheel is still spinning. Hold foot on brake to stop wheels then engage it.
  5. joe016
    120
    29
    Jan 23, 2016
    that what i thought but not too sure. The center diff lock is the one i use thanks for the help.
  6. Oxbow
    Oxbow Road Train Member
    12,539
    128,942
    Nov 24, 2015
    How many do you have? Do you have lockers as well?
  7. joe016
    120
    29
    Jan 23, 2016
    Yes I have a center different lock that the only one I use and I have wheels lockers too I think that what there call I upload a picture of the two I have .
  8. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    Are you driving a Tri drive???
  9. joe016
    120
    29
    Jan 23, 2016
    No it a tandem tractor
  10. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    both the power divider/inter axle lock and the wheel locks/ full lockers can be engaged at any speed as long as the tires are rolling n not spinning out.
  11. Oxbow
    12,539
    128,942
    Nov 24, 2015
    Some axle (full lockers) will not engage in the high side of the transmission, and, if engaged while in the low side sill disengage automatically when shifting into the high side. At least the 2005 Pete that I drove was like that.
