Digital Tire Pressure System - Worth It?
Discussion in 'Ask An Owner Operator' started by Matthew77, Sep 16, 2018.
  1. Matthew77
    Matthew77 Bobtail Member
    I've been looking into the cost of getting a digital tire pressure monitoring system that will constantly monitor my tire pressure as I'm driving a reefer from hot to cold areas. The lowest cost system I've found so far goes for $370. Do you guys think a system like this is worth it? Is there anything better than this out on the market?
    Thanks,
    Matthew
  3. xsetra
    xsetra Road Train Member
    5,197
    7,148
    Aug 21, 2011
    Don't know what system you're looks ng at.
    I would get a system that monitors pressure and temperature.
    Good luck
  4. brian991219
    brian991219 Road Train Member
    3,023
    6,202
    Aug 10, 2013
    Lords Valley, PA
    Yes, as long as it monitors in real time both pressure and temperature with an alarm to warn before a critical event occurs.
    The cost of one roadside repair avoided more than pays for the system and upkeep, and it becomes even more valuable if it avoids a steer tire failure. As you may know, steer tire failures are often expensive due to collateral damage -if not even catastrophic due to loss of vehicle control and crashes.
    I believe TPMS should be standard on all on-highway vehicles, not just passenger cars and light trucks/suvs
  5. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Yes, they are nice, and worth the money. You can check all the tire pressures in 10 seconds. It will tell you when something happens and you start loosing air pressure on if the tire is getting hot.
    There are "false alarms" sometimes. Sometimes it will tell you a tire is hot when you know it shouldn't be. It will figure it out in a min or two. Probably a disruption I .the radio signal from the monitors.
    slow.rider and bigguns Thank this.
  6. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    507 Series - 10 SCE Cap Sensor TPMS System
    We got these a while back. I think we paid closer to $500. But this is a 10 sensor kit. Good for a whole tractor or a trailer and the steers which is what we did. Since the purchase we were impressed. Easy to set up. Accurate. Very convenient and time saving. Helps keeps tires equal to each other in pressure. I think all his units now are the monochrome screens which are the good ones. Plug straight into a cig 12v port.
    bigguns and Accidental Trucker Thank this.
  7. Accidental Trucker
    Accidental Trucker Road Train Member
    3,439
    7,815
    Jun 4, 2015
  8. HopeOverMope
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    No they’re just sensors for psi and temp that wirelessly sends info to a monitor in the cab. What I mean is by keeping an eye on the screen you’ll always know where your tire pressure is at, so you can keep everything even with each other by adding air or taking away
  9. Accidental Trucker
    3,439
    7,815
    Jun 4, 2015
    Thanks, that's what I would prefer. The cross over lines of the Cateyes were not treated well by tire monkeys.....
  10. HopeOverMope
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Ten4. We had crossfire’s on the trailer. Broke at least one during tire changes.
  11. Accidental Trucker
    3,439
    7,815
    Jun 4, 2015
    No kidding. In three years, only two of them left on a three axle trailer. Find them in the side boxes, no explanation given.
    I'm hoping this is a better mouse trap, plus it gives real time warning of a flat. That would have saved at least one OOS with road service call and new tire over the last year.
