Direct drive bus gear ratio
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Swadian, Oct 28, 2018.
  1. Swadian
    Swadian Light Load Member
    184
    51
    Jan 21, 2017
    Reno, NV, USA
    I have a MCI 102D3 long-haul bus, curb weight 30500 lb, GVWR 44400 lb, used as express bus in Nevada on long desert highway drives (regular long-distance route, NOT a charter bus). Engine is Detroit Diesel 6067WK28 (Series 60 11.1L 365hp). Transmission is Allison HT746 4-speed automatic, direct drive in 4th gear. Current gear ratio is 3.21:1. Tire size is 315/80R22.5.
    I'm going 70 mph all the time here and I feel like the engine RPM is way too high at these speeds: frequently getting to 1700 RPM or above. I want to bring down the RPM. Should I replace gear ratio with 2.64:1 or 2.79:1 to save fuel? How much might it cost, and where can I get it done?
    Again, I'm 80-90% of the time running at 70 mph on the highway. Engine is in great shape but I'm frustrated with the RPM. Any advice?
    Please move to appropriate forum section if this is inappropriate.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Do you have access to the temperatures of your engine, trans, and axles? If all are happy at 1700 then you have a little room to run the upgrades common in the west.
    It's not much difference than a full 2000 500+ Detroit at 1650 and 63 in my time. To me that's slow in RPM, I started with trucks that wind out to 2300 with a variety of engines and ungoverned in my time. All of the engines with a couple of exceptions have done well. Later engines redlined at 1950 or 2100 depending on what you had. And there isnt much useful horses or torque on the engine chart at those levels. Just speed.
    Detriots like to run, but are not like Cats. They can however lug when it's time to do it. That means coming down from 1600 towards 1200 maybe before taking the next gear down. They work hard to give up the RPM's in that situation.
    My answer is food for thought. It is not a solution or adding to the problem. Gear ratio is not my forte, but if you are running 1700 at 70 or whatever out west, that's nice. As long all of your temperatures are happy.
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    its been a long time sense iv run an 11.1 detroit but i seem to remember them liking to be in the 14-1800 rpm range, there are some calculators online you can find in google search plug in your rear end ratio and speed and tire size i would probably want to target to be around 1500 rpms at 70. that bus was probably originally setup to cruse at 60-65
    wore out and magoo68 Thank this.
  5. Banker
    Banker Road Train Member
    4,113
    11,939
    Aug 19, 2012
    I run low pro 22.5’s on a car carrier with a Series 60 12.7 Detroit, 2:64 and 18 speed. I run in 16 up to 65 at roughly 1550 rpm. I run in 17 up to 75. I am not sure with your transmission how this would compare to my setup. Eaton has a great online tool, road speed calculator. Maybe it will help with your setup but I am not sure with your transmission.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    That 11 litre may not be happy with 2.64 or 2.79 .. rpm may be too low for a low hp low torque engine from that era .. talk to a knowledgeable Detroit rep and see what they recommend .. there’s very few people here who have ever run a 11 liter series 60
    wore out Thanks this.
  7. Swadian
    184
    51
    Jan 21, 2017
    Reno, NV, USA
    A small correction, it now seems like the bus is running at nearly 1800 at 70 (redline at 2100). It has a 4-speed auto Allison HT746 so I can't really shift it much. Mechanic at W.W. Williams says I should bring it down to 1500 for better MPG, but I don't know how knowledgeable he is about a Series 60 11.1L.
    The engine and trans temp are fine, not sure about axles. The manual says "ENGINE TEMP" warning is not applicable to DDEC and says I should use 315/80R22.5, so I don't think I can put in larger tires because the wheel wells are closed in. I can't see much unless I go over a pit.
    Used an online calculator and found that the bus is geared for 60 mph at 1500. According to the calculator, 2.64 would get me to 70 at 1500. So if the mechanic is right, I should replace with 2.64. All of this has just become very confusing.
  8. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    315s on a drive axle? Seems like a really wide footprint for a bus.
    x1Heavy Thanks this.
  9. Swadian
    184
    51
    Jan 21, 2017
    Reno, NV, USA
    That's what it says on the build plate and manual:
    • Steer Axle: 315/80R22.5
    • Drive Axle: 315/80R22.5
    • Tag Axle: 315/80R22.5
    Everyone uses it on this model bus.
  10. Swadian
    184
    51
    Jan 21, 2017
    Reno, NV, USA
    Anything else on the gear ratio?
  11. someguy99
    someguy99 Bobtail Member
    Hi Swadian.
    Did you ever change the gear ratio on your bus ?
