Directional blinkers
Discussion in 'Ask An Owner Operator' started by spindrift, Feb 27, 2022.
  1. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    That are on the side of a trailer must be seen from the cab by the driver. Correct?
    77fib77 Thanks this.
  3. Long FLD
    Long FLD Road Train Member
    11,887
    48,788
    Mar 4, 2015
    I’ve pulled quite a few trailers that I couldn’t see them. On the pneumatics I pulled the center turn signals were back between the hoppers and not visible at all from the cab.
    Rideandrepair, lester and D.Tibbitt Thank this.
  4. D.Tibbitt
    148,413
    Ive never pulled a flatbed where they could be seen unless making a turn
  5. zinita17601
    zinita17601 Road Train Member
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    They are not meant for the driver to see but for the other vehicles around the truck
  6. Numb
    Numb Crusty Curmudgeon
    4,067
    9,360
    Jan 30, 2012
    Charlotte, N.Carolina
    pulled dry vans where they tucked under the bed a bit.
    only at night could you tell they were working.
    I liked the ones that bulged out and you could see them from the front or rear.
  7. spindrift
    3,233
    12,905
    Dec 2, 2014
    Texas
    I had Googled it earlier and found what apparently was an older FMC requirement. Pulled out my book and couldn't find it.
    Rideandrepair Thanks this.
  8. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    I've never heard of such a thing and one of my flats has them but I can't see them from the cab.
    D.Tibbitt and Rideandrepair Thank this.
  9. spindrift
    3,233
    12,905
    Dec 2, 2014
    Texas
    Back in 1996 it looked to be the law. See Footnote #4. The FMC has since removed that requirement.
  10. Long FLD
    11,887
    48,788
    Mar 4, 2015
    Footnote 4 is for rear side marker lights, doesn’t say anything about a mid trailer turn signal.
  11. REO6205
    REO6205 Road Train Member
    13,172
    60,500
    Feb 15, 2014
    California.
    When our trucks go through inspections at the scales the drivers never get asked if they can see the middle blinker so my answer would be no.
    As fussy as California is I'm sure we would have been cited for it by now if it was required.
  12. Lazer
    Lazer Road Train Member
    1,790
    2,850
    Jan 22, 2017
    If it’s OEM, don’t worry about it.
