Dish detergent to clean oil sludge out of the cooling system?
Discussion in 'Experienced Truckers' Advice' started by glenn71, Oct 29, 2015.
  1. goin2fast10
    goin2fast10 Medium Load Member
    308
    26,022
    Dec 29, 2007
    Where I want to be
    Gasoline engines don't have oil coolers.
    In an oil cooler the oil passes through a 'cooler' (which has coolant in it going the opposite direction), usually pretty thin material comparatively speaking (like a radiator but slightly thicker). Ruptures or gasket failures aren't uncommon.
    glenn71 Thanks this.
  3. glenn71
    glenn71 Medium Load Member
    658
    294
    Jul 13, 2013
    Oh, I know that, but it's not unusual to flush the system on gas engines either. I just had never heard of using dish soap and water to do the job.
  4. PeteyFixAll
    PeteyFixAll Medium Load Member
    373
    8,071
    Oct 26, 2015
    Typically when an oil cooler leaks, oil shows in the water because the oil is under more pressure (roughly 30 -70 PSI) than the water (roughly 5- 15 PSI)
    When water shows in the oil typically either a liner or gasket on a water passage (head, air compressor, water pump on some, etc) leaking into the crankcase because the water is under more pressure than the air in the crankcase.
    Either way makes a disgusting curdled crapacino like snotty mess. if caught quickly little extra damage will be had. If missed or ignored, Big Bad news will be headed your way:(!!!
    Now in the operating room some of your mothers favorite cleaning supplies and really hot water usually work better at cleaning up that MilkofNastyness better than anything from the parts store.
    clausland Thanks this.
  5. PeteyFixAll
    373
    8,071
    Oct 26, 2015
    The soap is only for cleaning up oil. soap is not caustic enough to get rid of the normal cooling system residue. for that you need to use either a antifreeze flush product or CLR, Limeaway, type product. and not recommended on a tender radiator. And the reason I suggest using some type of bottled water for refill. Distilled would be best but not necessity. your Coolant and cooling system will last longer with a high quality antifreeze and good water (few or no minerals)
    Sorry for the Long Ramble
  6. AModelCat
    159,127
    I can't see the harm in it. I would be hesitant about leaving it in there too long because water has no corrosion inhibitors. Would definitely recommend re-checking the coolant strength after letting it circulate as you won't be able to drain out 100% of the water.
    not4hire, goin2fast10 and clausland Thank this.
  7. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    I've always used cascade, works great and dissolves any mineral deposits too..
    goin2fast10 Thanks this.
  8. Obscured.By.Clouds
    Obscured.By.Clouds Light Load Member
    53
    104
    Oct 27, 2015
    Dawn is the best for cutting grease,and rinsing clean.
    My buddy makes eyeglasses..Jim Jay..eyewear 20-20.
    Dawn is the only product they use,for cleaning their optics.
  9. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    I've used liquid Shout with great results as well for flushing cooling systems. CAT makes a cleaner designed to be left in for a couple days at a time but you're limited to using it above freezing obviously. Just remember to rinse several times when done and all the products mentioned above will do the job.
  10. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    You will find engine oil coolers on gasoline engines but usually on 3/4 ton and above pickups set up for towing and even then, it's an air cooled unit mounted on the radiator.
  11. AModelCat
    159,127
    Won't foam up either. We used to use it for cleaning out barrels.
