DIY Maintenance
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Kozakvod, Apr 11, 2018.
  1. Kozakvod
    Kozakvod Medium Load Member
    384
    605
    Jan 24, 2013
    I have always been the type to tinker into things myself. In the past I would have just taken the tractor or trailer to a shop and had someone fix whatever the problem may be. Last year before buying the new rig we were east bound out of Ft Stockton TX when I felt a terrible bumping on the right front wheel, at 65mph. Before I could get a new thought out, at 430am, i saw the wheel, drum, and hub take off across the median (never did find that wheel, as it disappeared into the dark). If it hadn’t been for having an overhead rack there would’ve been a monumental mess on I-10. A month earlier I had the wheel seal replaced. And the ONLY way the entire wheel system comes off is because they didn’t put the keeper ring on and that’s why it took an entire month to back off and drop the hub.
    I decided right then and there, never again. Never again would anyone touch my truck that didnt have the ability to accept responsibility for the work they do. So I decided whatever I could do I would do myself.
    So now, I have a torque multiplier and a set of all the tools I need to replace a seal, change a tire, whatever anytime anywhere. Never again, will I be at the mercy of some second rate shop. Long and the short of it, who else does this? Is this more or less common? Thanks!
  3. NuCar Carrier
    NuCar Carrier Light Load Member
    132
    314
    Jan 23, 2016
    I believe in the division of labor, I'm a carhauler not a mechanic. I'd be more concerned if I fixed it than someone who at least has a clue what they're doing. Not to say I can't jerry rig something to get to a shop but if it involves oil, tires or anything more than a 6" crescent wrench I'm done, even when I owned the truck. If I couldn't afford to pay for it, I was in the wrong business.
    I've never had a 'you picked a fine time to leave me front wheel' experience but if I do I think I'd be contacting the legal division of labor. Glad you're safe and sound but I'm thinking you may be overreacting.
    BigBob410 Thanks this.
  4. Kozakvod
    384
    605
    Jan 24, 2013
    Money isn’t the issue, never was about the money. It’s about the quality of service. Sure there are quality shops around, but they are few and far between. And those shops all shops charge an insanely large $ for generally what could be classified as second rate work. I could go as far as I want with this shade tree movement, but there are some things that I don’t want to do, PM’s for one. There is a shop down here B-Line, 4 locations around TX, and Ive not found anyone who does it better. So it’s not everything, but I can take wheels off, I can change my brakes, I can replace a bad seal, etc. Hendrickson provides great technical services manuals on how to do these things. Anyway. I know it’s not for everyone, just curious about those that do. Thanks @NuCar Carrier for the words.
  5. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    I had a similar thing happen- But didn't lose the wheel end- had a stupid Pilot in north Alabama do I simpleton wheel seal on the passenger steer- Leaked after 2 weeks- I Said "Never again, I started doing ALL my own work now.
    Had a pinion seal leak on power divider- Dipchits put in a sleeve and seal together and made a small leak even bigger-
    Moral of the Story- hard to find quality- Do it yourself- Nobody will care for your truck like you will.
    BigBob410, Kozakvod and Hulld Thank this.
  6. spyder7723
    spyder7723 Road Train Member
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    If you want it done right, do it yourself.
    DSK333, BigBob410, Kozakvod and 4 others Thank this.
  7. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    Am definitely for the DIY method vs shop IF you know what you are doing. Maintenance or changing a compressor type things are doable for the avg person. But if the problem dealt with brakes or wheel assembly, always tried to get back to my home area where I know the mechanics/shops.
    BigBob410 and brian991219 Thank this.
  8. spyder7723
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    Brakes and wheel seals are stupid easy. A quick google search and a YouTube video or two and you would be proficient if you have any common sense.
  9. brian991219
    brian991219 Road Train Member
    2,929
    5,833
    Aug 10, 2013
    Lords Valley, PA
    I am qualified to do all my own maintenance work, started my career as a mechanic. That said, I would sub out most of my work to qualified shops just because I did not want to spend my time off the road working on the truck. Now with a roadside breakdown I would do the repair myself as often as possible, especially if I didn't know the local shops.
    As for the OP's issue, I had the same thing happen just last year. Had a large tire shop that has locations all over from PA down to VA do kingpins, wheel alignment and new steer tires. Within 2 weeks the left front wheel assembly decided to come loose. I was lucky, I felt it and stopped just before complete separation. If it had come off I would have most likely wrecked the truck as I was just about to enter a single lane stretch of I-84 between the 46 and 34 in PA. Almost home. I have pics of the retainer clip installed backwards (the yellow painted side goes towards the inside) and the tire shop would not accept responsibility for the resulting damage and extra repair. Ended up costing them a loyal customer of many years, and I took them to small claims court and won.
    So, even "professional" shops don't always get it right. Don't have blind faith in the shop, always double check the work and if you are not sure ask. I don't expect drivers to be fully proficient mechanics but usually you can find something out of place with a good visual inspection.
    DSK333, BigBob410, Hulld and 2 others Thank this.
  10. LBZ
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    Hypothetically & out of curiosity. The scenario the op posted happens again. Except this time the flailing parts or the truck ran into another car on the highway. Would there be any difference in the outcome if you did the work yourself or if could point to shop abc doing the work with regard to how insurance companies or DOT may respond? I understand or am assuming shop abc would more than likely deny any responsibility.
    I have helped out with brake & drum changes etc. But kind of wanted a shops stamp on the work via receipt in an absolute worst case scenario. Same for when I had the king pins done.
    NuCar Carrier Thanks this.
  11. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    How are you breaking lugs loose over the road ?? Tapping into the trucks air supply?...
