DIY work?
Discussion in 'Questions From New Drivers' started by grayman, Dec 30, 2010.
  1. grayman
    grayman Bobtail Member
    15
    5
    Dec 9, 2010
    Denver, CO
    I’m still in CDL school but will be driving a truck very soon! I have a question about how companies look upon drivers doing some of the regular maintenance on their assigned trucks. I could see how a company would want a current certified mechanic completing major and safety repairs. But what about general stuff like changing fluids, filters, leaking seals, repairing hoses, belts, wiring, lights, wipers, changing and inflating tires, repairing cab parts and accessories, inverters, etc? For example, you are on your ten hour on a tight schedule and the oil has to be changed and you want to change it yourself so you don’t have to make a scheduled maintenance stop the next day. I could see why companies may not want you to do this but I’m curious what company policy is. I’ve worked on all my vehicles all my life and trust my work more than shop mechanics. I graduated from a certified automotive school a long time ago.
    ac120 Thanks this.
  3. ac120
    ac120 Road Train Member
    1,072
    550
    Aug 27, 2010
    Depends on the company, but I'll bet the answer is universally 'No.' That's why they hire mechanics. And if you're on your ten and you work on the vehicle, then, technically, you're on-duty. And . . . where the hell are you going to dump 41 quarts of oil? If you're a company driver you don't
    determine oil-change intervals.
    If something's wrong, you tell your company. Unless it's something like a light bulb, relax and let them take care of it.
  4. Bumpy
    Bumpy Road Train Member
    6,529
    5,257
    Jan 27, 2009
    New Ulm,MN
    At least you will be ahead of the "game" if ever deciding to be an owner-op..:biggrin_25525:
    ac120 Thanks this.
  5. Gonzo_
    Gonzo_ Medium Load Member
    307
    143
    Oct 30, 2008
    Clayton, NC
    Most company trucks are under warrenty if they are 3-4 years old.. They don't want some driver botching somthing up and causing a lot more problems than there was at first..
    Sure a lot of drivers can do simple stuff like hang a mud flap, change a headlight, but when it comes to anything else.. they want a certified mechanic to adjust brakes, do oil changes, ect.
    On todays trucks you need to many specialized tools and laptop computers with $1000 software to diagnose a trucks sensor problems.... plus a ton of tools.. You couldn't carry enough tools with you to do anything..
    If you want to do somthing.. keep your truck clean, (most companies wont mind if you polish your aluminum) Leave the mechanical stuff to the company.
    ac120 Thanks this.
  6. grayman
    15
    5
    Dec 9, 2010
    Denver, CO
    Thanks guys. That's kinda what I figured but thought I would ask.
    ac120 Thanks this.
  7. Allow Me.
    10,677
    12,240
    May 28, 2009
    Rancho Mirage, Ca.
    No, you don't do major or even minor repairs to a company truck, exception being a light bulb or mud flap. But, you will be miles ahead of the game if you can diagnose and repair small problems VS calling the shop, getting authorization, then getting into a shop and waiting etc. I would rather buy and install a headlight and get going instead of going through the companies procedures and taking 4 hours to do it. Especially if I'm in a time crunch.
    chompi Thanks this.
  8. Teaforone
    Teaforone Light Load Member
    200
    70
    Nov 16, 2008
    In the Sandhills, NC
    If you ever decide to try even minor repairs yourself do not tell your the company you hope to work for that you did it. Most big companies have a policy like this:
    You Work On It, You're Fired!
  9. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    Allowme has a very good point. If you are able to diagnose the problem that will save you a lot of time. Could make the difference between a tow truck or not too! If your on the side of the road and you know what part you need to fix the problem then that will definitely expedite the process. Road call will know what to bring with them. This is crucial if you are 200 miles from a shop!
    Like the other posters said as far as everything else the companies are going to want their guys doing the fixing and maintenance. Most companies won't even send you to certain shops over the road. They have their own network of people out there that fix their stuff. Hell even if you are leasing, they want you to use their shops! On these big rigs they do oil analysis with every oil change just so that they can keep their warranties on these things. Other than that stuff it's good to keep bulbs, fluids, mud flaps, hoses, nuts and bolts and tools with you. Now the reefer is a different story. If that thing goes "kaput" then they want you to do whatever it takes to keep it running.
  10. grayman
    15
    5
    Dec 9, 2010
    Denver, CO
    Good info guys. Thanks.
  11. Lonesome
    Lonesome Mr. Sarcasm
    11,182
    22,959
    Dec 15, 2007
    Northern Indiana
    Maybe get a job in the shop? Or work for a small outfit, and maybe wrench on the weekends?
