DIY
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TripleSix, Dec 10, 2009.
  1. TripleSix
    132,641
    Pulled a 12 ft wide load from Texas to VA. Got into Tennessee and shut down because it got dark. Next morning, I checked over the truck, kicked the tires, tapped the securement, caught up the coloringbook, checked the brakes, tugged against the 5th wheel and started to go. Heard a pop and then something scraping the ground.
    "This is going to be a bad day"
    A driver runs up and tells me that I just lost a tierod end. I jump out and see that the passenger's side balljoint slipped out. I put the balljoint back in the socket, grabbed a couple bungees to keep it from falling out. I backed into the parking spot I'd just left and got on the computer. Found a couple nearby parts dealers and I called them up. Closest tierod for my truck was Tulsa,OK. "####!"
    Told the clerk to overnight it and to bring it to me as soon as it got there and to bring a picklefork.
    Next day 10am, guy in a pickup knocks on my door. I jump out and break out the tools. Pliers to remove the carter pin.1 inch drive socket and cheater bar to remove the nut. 3 lb hammer and the picklefork. Measuring tape. Grease gun. New carter pins. Had both sides apart and back together in nothing flat.
    Guy in the truck says, "You've done this before." Not exactly...first time on a bigrig.
    You dont have to be mechanically inclined to be an O/O, but you do have to carry your own tools. Want to keep costs down? Learn how to turn a wrench. An afternoon's work can save you thousands $$$$
    Met a driver awhile back while eating breakfast at a TA that showed another driver and I a service receipt where he paid $900 for a truck service (no joke). He popped his hood and the first thing I noticed was his fuel filter was bad. I hurt this driver's feelings when I told him that the shop did not service his truck. Old filter, no grease, old air filter,...etc.
    If you dont want to turn wrenches, at the very least know the tell-tale signs of a good PM service.
  3. VARITHMS
    VARITHMS Medium Load Member
    476
    106
    Nov 26, 2009
    HOUSTON
    Cudos to you. It also feels good to have doen it your self. Last road side repair for me was the water pump to oil cooler hose. Replaced it with a vacume truck suction hose and monster clamps. It took about three hours, but it would have taken that long for a service truck to even get to me. 3 hours and 15$ and I was on my way.
  4. TripleSix
    132,641
    Thanks, V
    I originally posted this thread in the O/O forum in hopes that the O/Os there would post a list of the tools that theye carry on the truck for those DIY jobs so the guys that are looking to get their own rig can have an idea of what to carry on their own rigs.
  5. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    I think I've got every tool that I own on this truck.... Can't say what they are since I'm not sure what exactly I gots.... Everything is dumped into a box!
    My last roadside repair was a power steering hose.... The heater hose I used is still holding nice & strong!
  6. VARITHMS
    476
    106
    Nov 26, 2009
    HOUSTON
    Basic tools for me in the truck:
    -Stander ratchet sizes up to 3/4 same for wrenches. Must have a swivel and extentions.
    -metric sizes up to 22mm same for wrenches. Don't buy the stets that skips sizes the ones they skip are the ones you will need.
    -duct and eletrical tape
    -pliers; regular pliers, channel locks and 12" pipe wrench
    -hammer
    -basic screw drivers
    - beer bottle opener. great for geting stuborn lights out. and the obvious.
    JustSonny and montana cowboy Thank this.
  7. Elvenhome21
    Elvenhome21 Heavy Load Member
    735
    240
    Nov 17, 2008
    Sheboygan, WI
    VARITHMS Thanks this.
  8. haystack
    haystack Light Load Member
    177
    22
    Feb 12, 2009
    I would also include open/box end wrenches up to 1". Those are what would be needed for fuel lines and air lines. Oh something else.... a dime. You may ask why a dime? You can squeeze the dime down just a weee bit and it works great for plugging off an air line that goes to a brake pot, or a return fuel line if the bottom valve gets broken off a fuel tank. Just remove the line, put the squeezed down dime in, then re-install the line and it works like a plug, not much air, or fuel will seep past.
    JustSonny and VARITHMS Thank this.
  9. TripleSix
    132,641
    Some of the tools I carry
    -1/4,3/8,1/2,1 inch drive ratchets with sockets
    -box wrenches with ratchet ends
    -3 ft breaker bar(for changing tires...I use the cheater bar for extra extension if needed)
    -20 ton hydraulic jack (did a full brake job...new drums even...in a truckstop parkinglot)
    -3 lb (BFH) and 20 lb hammers (for dunnage that tries to walk)
    -4000 lb 'come-a-long' steel cable winch (for repositioning loads)
    -2 spools of wire (have had to rewire trailers to get them to work.
    -spare airbrake pod
    JustSonny and future driver Thank this.
  10. VARITHMS
    476
    106
    Nov 26, 2009
    HOUSTON
    I have not seen anyone change a tire themselfs in years.
  11. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    JUMPER CABLES!!!! :biggrin_2551:
    VARITHMS and Chain Drive Thank this.
