Do’s & Dont’s on clutch & clutch brake!
Discussion in 'Questions From New Drivers' started by ua96, Aug 26, 2024.
  1. ua96
    ua96 Bobtail Member
    19
    18
    Aug 24, 2022
    Just to start off I’m not really a new driver but I’m about a year in driving 8LL. My employer purchased a used truck during spring time & I’ve been driving it since. It was good at first until my clutch brake went & the mechanic installed a 2 pc clutch brake that only lasted me about a month. This weekend he had a driver fill in & as soon as I hit the highway this morning I felt the clutch slip. What could’ve caused this?
    I’m local dump truck driver & I stop & go pretty frequent. I float gears, usually downshift to lowest gear & pop it into neutral at a red light. Use clutch brake completely stopped to stick it into 1st (empty) or Lo (Loaded) & usually let the truck roll with the clutch. That’s the only time I use my clutch & clutch brake but I’m just confused as to how or why both went so fast. Mind you truck currently has 105k miles.
    To the local drivers or otr drivers that stop & go frequently in cities what are your do’s & don’ts to help preserve your clutch & clutch brake?
    77fib77 Thanks this.
  3. 77fib77
    77fib77 Road Train Member
    10,619
    66,782
    Jul 7, 2010
    St Louis
    Don't put the pedal all the way to the floor unless you can't get the transmission into gear. Or, you cant get it out of gear. It's only close to the floor that you wear your clutch brake.
    When you get rolling from a stop. Try to get out of the clutch quickly, then add power. My truck was strong enough to pull with out added throttle. So I could get out of the clutch pretty quick. Granted I was OTR and not driving in West Virginia or Pittsburgh.
    ua96 Thanks this.
  4. pavrom
    pavrom Road Train Member
    3,185
    7,305
    Apr 29, 2012
    NE illinois
    I did 375k on my clutch being otr( ...not sure how many miles it had before i installed engine ), every day loading/unloading ...same here : clutch used only for 1st gear
    you can't kill clutch brake in 1 month unless it's intentional abuse ...I believe so ...I'm sure more knowledgeable guys will chime in
    Arctic_fox, ua96 and 77fib77 Thank this.
  5. AModelCat
    159,375
    If the clutch is starting to slip I would have the adjustment checked ASAP (assuming its not a self-adjusting clutch). If there's no free pedal then there's a good chance you can save it before you cook it since you caught it early.
  6. ua96
    ua96 Bobtail Member
    19
    18
    Aug 24, 2022
    I asked for an adjustment but was told that it should self adjust. It’s a 2020 KW
  7. Ridgeline
    22,407
    116,548
    Didn't you start another thread with the same question Thursday?
    I said (and got bashed for it) that you keep it in gear until stopped and then put it into the starting gear, you don't need a clutch brake.
    About the clutch slipping, even if they say it is self-adjusting, it may need to be looked at or replaced, I think replaced.
    OldeSkool, Oxbow and ua96 Thank this.
  8. ua96
    ua96 Bobtail Member
    19
    18
    Aug 24, 2022
    Yes I did! I did see a couple guys opposed of your comment lol I do this method a good amount of times but I also pop it out of gear from time to time. But question, holding the clutch in gear wouldn’t it mess up the throw out bearing after a while?
  9. Phoenix Heavy Haul
    Phoenix Heavy Haul Medium Load Member
    469
    1,397
    Feb 8, 2022
    Raleigh NC
    Resting your foot on the pedal while driving, even slightly will take one out.
    OldeSkool, Oxbow, RockinChair and 4 others Thank this.
  10. Ridgeline
    22,407
    116,548
    I don’t think it does, seeing that the engineers have taken in account the load on the bearing. Clutch covers or pressure plates seem to have been used for decades without causing too much issues for the bearing.
    the life of the bearing should be longer than that of the clutch discs, seeing that the clutch plate material is a consumable and has a limited useful life.
    Oxbow, ua96 and OldMainiac Thank this.
  11. abyliks
    abyliks Road Train Member
    3,895
    9,114
    May 2, 2010
    ludlow MA
    The self adjusters seize over time, realistically a good driver will have a disc go or a spring break before actually wearing the clutch out
    sometimes the 2 piece clutch brakes come unhooked, can also check pedal linkage
    OldeSkool and Oxbow Thank this.
