Do Any Company Trucks Have Thermostats?
Discussion in 'Questions From New Drivers' started by insipidtoast, Jan 29, 2023.
  1. insipidtoast
    insipidtoast Heavy Load Member
    991
    661
    Nov 22, 2016
    Planet Earth
    I know people on here like to get in debates about safety from time to time, but I can't take a company's safety department seriously if their trucks use opti-idle. If you're not a very heavy sleeper, you're going to be woken up by that truck engine starting itself in the middle of your sleep. They like to flap their lips about the importance of getting proper sleep, but somehow fail to realize how their equipment screws with your sleep.
    How about those APUs too? If I'm hot at bedtime, and set the thing to the coldest setting am I going to be Okay all night or will I get woken up by being too cold, because the thing can't regulate itself. Thermostat technology has been around for what, a hundred years? Why hasn't it found its way into truck cabs?
  3. Arctic_fox
    3,939
    20,170
    Sep 16, 2016
    My greenapu does a pretty good job self regulateing. The worst i have recorded was 3 degrees off from what i set it to.
    As towards the tech its a combination of things. Biggest one however is cost. To a O/O like me i would just pay the extra $150 to make my cab nicer. To a fleet like swift buying tens of thousands of trucks where half end up in the ditch withij a year anyway....$150 per rig is now almost $4 million bucks not worth it to them. Its dumb but these trucks are catered to the money makers. Not the drivers. So if they can save millions in equipment a year they do.
    There are other reasons too but thats the big one. Its also why you see O/O rigs even ones like mine that started life as a fleet rig start to get little QoL upgraded either at purchase or wired in as time and money permit.
    insipidtoast and motocross25 Thank this.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,767
    Mar 5, 2012
    Ontario Canada
    They work great.
    You'll get used to engines firing up at all hours, trucks driving by, air brakes, and will sleep through all of it. A sound that doesn't belong will wake you i.e. glass breaking or knock on your door.
    Hammer166, tscottme and Suspect Zero Thank this.
  5. Terlingua
    Terlingua Medium Load Member
    487
    1,019
    Oct 24, 2021
    Schneider’s newer trucks have the battery powered electric APU. The one I’m in now has it. The truck I had before had a Thermoking diesel APU so I wasn’t sure how I’d like the battery one, but I love it now. Very quiet and no vibration at night. Even the diesel APU can be distributive of sleep when it starts and stops. Maybe not quite as bad as the main engine. The thermostat doesn’t have specific degrees, but you figure out where you like it and it keeps it a pretty constant temperature.
  6. Turtlelegs
    Turtlelegs Light Load Member
    84
    158
    Apr 15, 2022
    It has.
    I'm not aware of any companies that require a driver to use opti-idle.
    tscottme Thanks this.
  7. Terlingua
    487
    1,019
    Oct 24, 2021
    If you don’t have at least an electric APU to go with it, then you have to use opti-idle in comfort mode to stay cool in warm weather
  8. Turtlelegs
    84
    158
    Apr 15, 2022
    I know - my point is that I'm not aware of a company that forces a driver to use opti-idle. I don't have an apu but if I'm willing to put up with the heat then I don't have to opti-idle.
  9. tscottme
    tscottme Road Train Member
    The Webasto bunk heaters I had all had a digital display, pictured in post #3 for temp setting. My bunk heaters also had a 10 hour timer so that it would only run for 10 hours since the last time you activated/changed the temp setting, or until you turned the truck ignition switch to run or start position. If you were taking a 34 hour reset in some area with prolonged cold temps and you were using the bunk heater every 10 hours you would need to turn the heater back on or adjust the temp before it shut off at 10 hours.
  10. tscottme
    I've never had any truck with Opti-Idle or an electric APU. My trucks had no APU for many many years. And my trucks for maybe the last 10-15 years had diesel powered APUs and sometimes diesel fired bunk heaters. Opti-Idle is only on SOME trucks or in SOME company's fleets. Opti-Idle is just one of the many ways to provide a non-running truck with HVAC and electrical power.
  11. Terlingua
    487
    1,019
    Oct 24, 2021
    Yes, I should have said my bunk heater does have a digital thermostat control, even though it seems like it's about 10 degrees off. There's also a way to easily change the 10hr timer to make it longer. The ThermoKing and Freightliner ParkSmart APU controls I've seen have never had a digital thermostat.
