Do ANY major carriers hire from South Florida?
Discussion in 'Trucking Jobs' started by BigKahunaFL, Sep 12, 2008.
Thread Status:
Not open for further replies.
  1. BigKahunaFL
    BigKahunaFL Bobtail Member
    42
    8
    Aug 19, 2008
    After researching MANY companies, I've come to the conclusion that no one hires drivers that live in South Florida. Only a few of them even serve this area. What gives? Does anyone know of a company that I could hire on with that would hire a driver from down here?
    BTW - the hiring information is based on what I found on company websites. They usually have a little map that highlights both their operating areas as well as their hiring area.
  3. LadyDallasDriver
    LadyDallasDriver Light Load Member
    129
    56
    May 5, 2008
    USA
    Not sure what type of ork your looking for but I worked for Walpole Inc based in Okeechobee, Fl they mainly haul in Fl But they do go to near by states. Also I think PAM is in Jacksonville and may hire you. Check Publix, Albertsons, and watch the highways for trucks and get there info and call them.
    Good luck...:biggrin_25520:
    BigKahunaFL Thanks this.
  4. Bigarmin88
    Bigarmin88 Road Train Member
    1,791
    376
    Aug 30, 2008
    Tampa Bay Fl
    As what I can see,there very few trucking jobs here in Florida.Its so bad here im thinking of moving back up north.You may wanta look into ''starter companys'' like werner,swift,etc.Its also hard get a local driving job as well,unless you have at lease 1 year exp.
  5. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    FL is the freight black hole of the country. everything goes in and NOTHING comes out. when you do book a load to fl you usually end up bouncing out empty. companies don't hire there because they can't get you home without bouncing you out and that's too expensive these days.
    look at some of the food grade tank co's that run orange juice etc out of there.
    oakley, indian river transport are to on top of my head
  6. Eskimo6804
    Eskimo6804 Heavy Load Member
    816
    3,344
    Jun 13, 2007
    Northeast Alabama
    Also Bynum.
    If you don't mind commuting, there are quite a few companies with terminals in the Winter Haven, Lakeland area that you might try.
    WEL(Wisconsin Express Lines), Willis Shaw Express, Walbon and company come to mind here.
    There are a few Miami based companies, but most are owner ops. or small fleets.
    Another route you might explore are the container companies that run out of the ports down there.
  • Thread Status:
