Do brake chambers have brake fluid in them?
Discussion in 'Trucking Schools and CDL Training Forum' started by Newtotrucking2020, Dec 5, 2019.
  1. Newtotrucking2020
    Newtotrucking2020 Bobtail Member
    25
    9
    Oct 8, 2019
    When doing the pretrip would you say no audible leak and no brake fluid leaking from brake chamber or just say audible?
  3. LDLWells
    LDLWells Heavy Load Member
    782
    1,218
    Jan 14, 2019
    It's only air in that chamber. Fluid breaks down, air doesn't
    homeskillet and Newtotrucking2020 Thank this.
  4. snowwy
    snowwy Road Train Member
    20,591
    13,311
    Jul 6, 2009
    The only fluid you'll have in them chambers is water splashing from a wet road.
    The only brake fluid semi's have is the clutch.
    Newtotrucking2020 Thanks this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Fluid will burn at the temperatures that we do braking downgrade in mountains. You cannot find fluid strong enough to endure that kind of condition without catching fire. You also cannot use fluid to apply the required force to generate that kind of braking power.
    What does?
    Air. Compressed air, and a hell of alot of it.
    Bean Jr. and Newtotrucking2020 Thank this.
  6. 201
    201 Road Train Member
    12,635
    25,954
    Apr 16, 2014
    high plains colorado
    OMG, you have GOT to be kidding? They're new all right and I thought I heard it all.:biggrin_25513:
    Dumdriver, FlaSwampRat and Bean Jr. Thank this.
  7. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    i realize that you have a question, and asked it here, it's better to ask, then to either assume, or make mistakes at the DMV test site.
    however, if you are in any CDL school right now, that question would have been better asked to your instructor(s). in fact, your instructor should have told you it's an "air system", which would mean, no fluids of any kind in there.
    on an outside "chance" your truck has a bad air-compressor, there "might be" a trace of oil seeping out, but in all my years, i have never seen that...
    so " NO audible leak" would be all that you'd be saying...
  8. 201
    12,635
    25,954
    Apr 16, 2014
    I'd make a terrible instructor, there would be an even bigger driver shortage. BRAKE FLUID? GET OUT:biggrin_25516:
  9. buddyd157
    13,582
    34,896
    May 25, 2017
    under a shade tree
    but you know something.??
    it would not surprise me, if someone had a grudge against a company, and did pour "some sort of fluids", into the glad hands, and reconnect them. just like the old penny trick into the grommets.
    snowwy, FlaSwampRat and 201 Thank this.
  10. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    Heavy, I do respect your continued contribution to this forum.
    But this time, you're absolute wrong.
    The air itself does not produce any friction to slow down the vehicle, it is the brake liner. And for the brake liner, there is no difference what made the necessary movement to turn the cam and press it against the drum. It could be as well any hydraulic system.
    A bydraulic system provides even more than a 140 psi of pressure.
    The reason, why air is used, it's my assumption, air doesn't change its viscosity in cold temperatures whereas oil does. The brake system is not a continuous flow system and would leave cold oil in the lines, making it slow to react in cold conditions.
    FlaSwampRat Thanks this.
  11. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,896
    Sep 20, 2015
    Southern Ontario
    Also, any hydraulic system would need to be bled if they were disconnected anywhere or a break in the lines somewhere.
    Won’t be fun being under the truck in -20°c to -40°c weather laying in snow bleeding every wheel on the truck and trailer that got air in the hydraulic system.
    Air is a way better and more safer system to reliably work all the time in combinations vehicles.
    Every truck that has hydraulic brakes and pulls a trailer, the trailer is either electric brakes or electric over hydraulic.
    Just passing by and FlaSwampRat Thank this.
