Do chains make it a wide load?
Discussion in 'Flatbed Trucking Forum' started by turnanburn, Aug 26, 2012.
  1. turnanburn
    turnanburn Medium Load Member
    628
    270
    Jan 25, 2011
    central Vermont
    If my low boy trailer is 102 inches in width, and I use the D rings for the chains and binders, does the chain and the flipped up ring then make it a wide load? same question if the binders are hooked to the flange of the trailer as the hook then becomes wider than the trailer. Never had to answer this question driving my equipment around the farm properties, but need an education on this point. Machinery in question does not exceed trailer width. Thanks in advance.
  3. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    I have never had any problems like that, but then I do not run up the Eastern seaboard.
    turnanburn Thanks this.
  4. thedrifter
    thedrifter Medium Load Member
    522
    263
    May 23, 2010
    portland or.
    No the tie down rigging doesn't make it a wide load. I won't position my binders in a way that the handle sucks out from the deck but evev then it's not a wide load. But it is unsafe
  5. dirthaller
    dirthaller Road Train Member
    1,116
    13,152
    Sep 22, 2011
    Coloratah
    I read somewhere in the FMCSA bible that "cargo securement" does not count to measure the width of the load. Chains, binders,vee boards,tarps,etc.:biggrin_2551:
    SHC, turnanburn and V8SuperDog Thank this.
  6. snowwy
    snowwy Road Train Member
    20,598
    13,320
    Jul 6, 2009
    and how does it make unsafe. my binders stick out beyond the trailer about 2 - 3 inches sometimes.
    if someone is going to hit my binders they're defenitly going to hit my trailers.
    what makes it a wide load is anything that sticks out beyond the trailer. minus securement. one of our drivers said it had to be beyond 4 inches. but i don't put faith in anything he says.
  7. jbatmick
    jbatmick Road Train Member
    2,199
    2,507
    Dec 1, 2009
    hastings, Fl
    Probably depend on what kind of day the DOT officer was having.:smt062
    Cetane+, truckon, V8SuperDog and 5 others Thank this.
  8. DEMO
    DEMO Money Bags
    480
    349
    Mar 6, 2012
    Orlando, FL
    If only your securement is outside the leading edge of your trailer your fine. I'm doing it right now on my leagal width load from WI to RI. Have never had an issue in 20 years. Besides, if a DOT officer is going to pick on that issue... You have bigger problems....
  9. TruxRus
    TruxRus Light Load Member
    87
    36
    Jul 27, 2012
    Round lake beach Illinois
    Moved equipment for many years all over the U.S never had any problems for the chains being outside the edge of the deck
    turnanburn and aiwiron Thank this.
  10. turnanburn
    628
    270
    Jan 25, 2011
    central Vermont
    Thanks guys. Won't worry about that question anymore.
  11. cpape
    cpape Desk Jockey
    2,151
    2,263
    Jul 15, 2010
    Dubuque, IA
    It doesn't matter if the load "sticks out beyond the trailer." What matters is if the load exceeds 102" wide. If you have a 96" trailer, you could have a load that stuck over the trailer by 4 inches and was still legal width. If you have a 102" wide trailer, your load can not stick over the trailer at all or it is a wide load.
