Do dedicated reefer they said, it will be easy!!!
Discussion in 'Ask An Owner Operator' started by Elroythekid, Dec 24, 2021.
  1. Elroythekid
    Elroythekid Road Train Member
    2,606
    5,663
    Sep 9, 2010
    Halifax Nova Scotia
    Bills say 45000lbs .... air gauge was a little low scaled it, drives were just under 32k trailer just under 44k....
    Back to the DC , they take 3 skids off the tail, seal it up give it back. It's still really tail heavy, 39500lbs on the trailer, drives 33k now, so I head down the road.
    First stop, I'm not allowed to break the seal or touch it... they cant get the roll up door open... use the forks on the stacker..... and find....
    Over 6 ft tall stacks of heavy juice and yogurt, EVERYWHERE. No load bars, no straps, dont break them down.
  3. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,716
    Nov 7, 2021
    B.C. Canada
    WTF.
    Try getting a gig hauling logs.
    15 minutes to load, no seals, load is pretty much indestructible, 10 minutes to scale and unload at the mill.
    You have bunk scales and tell the loader operator how much wood you want on your truck.
    I've seen so many crashed and rolled logging trucks, they just call a self loading logging truck to come get it, and deliver it.
    No truck stops, nobody backing into you, the men are real men, no snowflakes, and money is good.
  4. Phantom Trucker
    Phantom Trucker Medium Load Member
    365
    660
    Jan 11, 2016
    Calgary, AB
    That’s the kind of crap that drove me out of that segment of trucking.
    Kyle G. and Pamela1990 Thank this.
  5. Pamela1990
    1,820
    10,716
    Nov 7, 2021
    B.C. Canada
    I wouldn't make it 3 days pulling a reefer, or van.
    It would drive me crazy.
  6. goga
    goga Heavy Load Member
    894
    1,586
    Nov 11, 2021
    Earth..
    39 k on the axle? Good luck with that))
    Saltyoldone Thanks this.
  7. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,935
    Apr 2, 2021
    TARHEEL
    D.C. = Destruction Center, Destroying Customers, Delivering Catastrophe.
    Loaded Loaders.
    Yep, such "is easy".
  8. 201
    201 Road Train Member
    12,339
    25,232
    Apr 16, 2014
    high plains colorado
    It's why you never just fling open a door, THIS is what could be behind it. Do you have any idea how many times this has happened to me? ALL,,,,THE,,,TIME,,,it was simply part of the job. More than once, I had to have the forklift pry open the rollup door, and deal with what lay behind. Now,,, I got paid by the hour pulling an icebox,, so I didn't care if the crap was oozing out the door, I made great money restacking it, and the best part, the dock crew, who are generally schmoes that can't wait to load the wagon and hit the bar before it closes, gets a well deserved axx chewin' from the boss. Unless you haul straight loads in a reefer, like 20 pallets of cheese, this is what goes in a reefer, all kinds of little things, and usually unstable. Many times, with such irregular shapes, the dock literally runs out of load bars. Quite frankly, I don't see the problem here, you asked for it when you said, "sure, I'll do it, how bad could it be?",,,:biggrin_25524:
  9. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    Look at the bright side. You weren't the guy blocking half the yard at the Costco a couple months ago. His load was like that, and his swing doors opened easily. Two tall pallets on the very back tipped right on over. It was like a little mountain behind his trailer. Not a good day for him. At least you were secure on the dock where they could work with it a bit more conveniently.
    201, Magoo1968, Pamela1990 and 2 others Thank this.
  10. Magoo1968
    Magoo1968 Road Train Member
    2,032
    5,426
    Mar 18, 2021
    St Malo mb
    Legal in Quebec and Ontario not sure about New Brunswick though
    tscottme and Pamela1990 Thank this.
  11. Elroythekid
    2,606
    5,663
    Sep 9, 2010
    Halifax Nova Scotia
    I've been almost 2 months... might not make 3. Being mty for half my Miles is great, saving a ton on fuel, but this crap isnt for me.
    Pamela1990 Thanks this.
