Do I ever need to do a manual parked regen without the truck asking for it?
Discussion in 'Questions From New Drivers' started by TawcoTruck, May 27, 2023.
  1. TawcoTruck
    TawcoTruck Light Load Member
    155
    224
    Dec 11, 2022
    The high exhaust temp light has been on for about an hour now at highway speeds.
    Edit: this just popped up on the dash
  3. JonJon78
    JonJon78 Road Train Member
    7,205
    42,177
    Jul 1, 2018
    Not saying I'm right but, in the two trucks I've owned with this clean air nonsense ( one current ) I've never done a parked regen...
    How many miles are on the truck? Possibly the filter is full or getting there and needs to be cleaned or changed?
    Siinman, Oxbow and Jubal Early Times Thank this.
  4. northstarfire0693
    northstarfire0693 Heavy Load Member
    863
    596
    Jul 1, 2006
    NC
    Unless the truck is telling you to park. Dont worry about it. Keep going and let it finish the regen.
    Jubal Early Times Thanks this.
  5. TawcoTruck
    155
    224
    Dec 11, 2022
    2020 357k intentional company truck.
    Numb and JonJon78 Thank this.
  6. Terlingua
    Terlingua Medium Load Member
    487
    1,020
    Oct 24, 2021
    Whatever the problem is, you're already derated 25%. If you don't get it fixed you'll find yourself on the side of the road. You need to contact your shop.
    Numb and tscottme Thank this.
  7. TawcoTruck
    155
    224
    Dec 11, 2022
    This popped up. Guess this is it.
  8. JonJon78
    7,205
    42,177
    Jul 1, 2018
    Ya better find a safe exit ASAP so you aren't sitting on the shoulder. Probably just a stupid sensor. Bad thing is, it's Memorial Day weekend...
    Oxbow, Numb, tscottme and 1 other person Thank this.
  9. northstarfire0693
    863
    596
    Jul 1, 2006
    NC
    You are having issues with the emissions system. Get it into the shop ASAP before it shuts you down. You should have enough time to find a decent truck stop to get into.
    homeskillet and JonJon78 Thank this.
  10. SoulScream84
    3,426
    26,268
    Mar 21, 2020
    Try the parked regen with AC off. The additional fans can make the heat insufficient to burn off the particulates. I didn't believe it, but had a truck regen for a couple of hours and debate due to AC running.
    Concorde, Numb and tscottme Thank this.
  11. northstarfire0693
    863
    596
    Jul 1, 2006
    NC
    I dont think that makes a difference with the A/C being off, but I could be wrong
