Do I need a new rear end?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Hodginshauling, Nov 23, 2021.
  1. Hodginshauling
    Hodginshauling Bobtail Member
    4
    You can hear a howling noise if you listen close in the video all of them spin like normal except the one you can see barely moving in the video. Pulled the axle on that side and it’s not broken!? Also no metal in either rear end.
    Any ideas?
  3. Diesel Dave
    8,829
    25,864
    Jan 20, 2010
    Hesperia, Ca.
    Drain the gear oil and see if there’s any chunks of metal. And stick in a spring magnet towards inside bottom to see if any metal comes out also.
    Rideandrepair Thanks this.
  4. AModelCat
    160,482
    Power takes the path of least resistance. If the brake on the wheel that is hardly moving is dragging a bit, its easier to spin the wheel on the other side (which will spin twice as fast). Normal differential action and not neccessarily cause for any concern.
    I didn't watch with volume so I cannot say anything about the howling.
    Rideandrepair and Bean Jr. Thank this.
  5. Lazer
    Lazer Road Train Member
    1,802
    2,872
    Jan 22, 2017
    Do the easy stuff first, drain both, examine what comes out. Refill both with synthetic 75w-90. See if problem improves, worsens, or no change.
