Do I need to lower my Fifthwheel to run Dry van?
Discussion in 'Ask An Owner Operator' started by RichTrucker2020, Sep 5, 2021.
  1. RichTrucker2020
    RichTrucker2020 Light Load Member
    129
    94
    May 30, 2020
    I have a truck that I used to run tanker with. The Fifthwheel sits higher for tanker work. Do I need to lower the stands to run dry van? [​IMG]
    feldsforever Thanks this.
  3. Arctic_fox
    4,044
    21,030
    Sep 16, 2016
    It should be fine afaik. Company i worked for did a bunch of dry van after oil dried up with the old oil equipmemt. Just need to make sure to mesure from the top of your trailer to the ground for your ground clearance as it may be a tad more then 13'6. Also may need to drop your airbags every time you back under.
  4. Numb
    Numb Crusty Curmudgeon
    4,048
    9,271
    Jan 30, 2012
    Charlotte, N.Carolina
    48" is ideal.
    dock height.
    Rideandrepair and RichTrucker2020 Thank this.
  5. abyliks
    abyliks Road Train Member
    3,856
    8,984
    May 2, 2010
    ludlow MA
    What size rubber are you on?
    what does the tape measure say?
    RichTrucker2020 and Rideandrepair Thank this.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    No you have low pro 22.5 already your good. I bet you'll be around 13.5 or so. That 5th wheel is probably 46in or so
  7. RichTrucker2020
    129
    94
    May 30, 2020
    Okay, thanks.
    Okay.
    Where do measure from?
    Cool.
  8. nikmirbre
    nikmirbre Road Train Member
    5,407
    9,729
    Jul 27, 2011
    High Point NC
    Id measure...it looks like you have 6inch risers on there.......
  9. okiedokie
    okiedokie Road Train Member
    12,182
    90,484
    Jun 13, 2011
    PNWET
    Grease 5th wheel.
    feldsforever and Cat sdp Thank this.
  10. Ruthless
    Ruthless Road Train Member
    8,931
    87,836
    Aug 28, 2010
    The City.
    Measure from the ground to the top plate of the fifth wheel when its level/ if its over 48” dry vans will be taller than 13’6” in the nose. Vans with 110” interior height are approximately 115” tall from the kingpin plate to the top of the roof. If you're in a 14’ state this will be less of an issue
    feldsforever and Roberts450 Thank this.
