Do Motor Oil's have there own unique Smell ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Diesel Dave, Nov 29, 2012.
  1. Diesel Dave
    8,683
    24,693
    Jan 20, 2010
    Hesperia, Ca.
    I recently had my oil serviced about 3500 miles ago. I have always used Chevron Delo 15-40. But recently since the service, I have noticed a different smell coming from the blow by. I checked for water in the oil, and oil in the water and all is clean, as a matter of fact the oil is still golden yellow. But the oil on the dipstick even smells like the odor from the blow by.
    Im thinking maybe they put a different oil in it, I tried to compare the viscosity by rubbing my fingers thru the oil and fresh oil from a Delo jug. The one on the dipstick was slicker, BTW I dont run Lucas anymore.
    I had a shop mechanic check it out and he said it smells like "synthetic". Now I use synthetic in my 4 wheelers and I did notice a resemblance on viscosity and slight on the odor. So did I get away of paying for regular delo in exchange for synthetic ?
    I have used Shell Rotella way back and didnt like it and it didnt have the smell Im speaking of, I have never use Delvac either, So can a few member's here enlighten me to what might have happen.
  3. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    I do know that blowby from Rotella smells completely different from Delo. Rotella has a very funky smell for the first 4-5000 miles.
  4. CrabbyOlLady
    CrabbyOlLady Bobtail Member
    43
    24
    Nov 2, 2012
    Washington
    I'm most definitely not an expert but have spent plenty of time under the hood of anything on wheels...so take this with a grain of salt.
    There are times when a shop will either screw up your order and grab the synthetic and not notice or they run short and hope you won't notice a swap. If it feels and smells synthetic - it is. The taste test always lets you know for sure: if its like peanut butter its delo, if its like caster oil you got synthetic. Go back to the shop (if possible) and have them explain it to you in person they tend to be a bit more honest when you are standing in front of them.
  5. Diesel Dave
    8,683
    24,693
    Jan 20, 2010
    Hesperia, Ca.
    I have had Rotella before and it didn't smell like it does now.
  6. Diesel Dave
    8,683
    24,693
    Jan 20, 2010
    Hesperia, Ca.
    Taste test !!!............ Hell, why not, it might do me good internally.........lol.... Seriously though, just might do that and go to the shop. I've been there a few times and never had a problem. For $220.00 I get oil change(choice of oil), lube and CAT filters. It's cheaper than me doing it myself.
  7. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    The rotella does have a unique smell, as does the different delvac varieties.
  8. little cat 500
    2,048
    1,094
    Jan 17, 2010
    Abbottstown PA
    i tryed that travelers oil from tractor suply that smelled kinda funky though the blowby tube for couple thous miles
  9. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    $220 for that service wow that's cheap, here it is $600 for oil change and grease tractor only, trailer is another $300. Australia the lucky country ha!
  10. Diesel Dave
    8,683
    24,693
    Jan 20, 2010
    Hesperia, Ca.
    By the time I buy the oil, CAT fliters(1 oil, 2 fuel, 1 water) and grease, Im close to $200.00. For another $20.00, the oil/lube shop could do it. Isn't that common sense ?
  11. CrabbyOlLady
    43
    24
    Nov 2, 2012
    Washington
    You don't taste your oil? Great. I think my age is showing...
    If you can get it done that cheap then yes, it makes sense. Some of us like to DYI cuz that's fun and you can check a few other things your shop won't over charge you for fixing down the road.
    No one said I was normal.
