"DO NOT PUSH".....?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by homeskillet, Jun 25, 2018.
  1. homeskillet
    homeskillet Road Train Member
    6,194
    47,376
    Jun 1, 2013
    Dayton, OH
    I've seen this for years on both straight dump trucks and end dump trailers. Some with top hinge doors, some with side hinge.
    Why do only some trucks say this on the back?
  3. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Because some folks have to be told
    Roger McG, bryan21384, Smut and 3 others Thank this.
  4. AModelCat
    161,506
    Or only some operators care about their equipment.
    homeskillet and spyder7723 Thank this.
  5. truCkanda
    truCkanda Bobtail Member
    10
    7
    Nov 16, 2017
    Possibly driver with short fuse behind steering wheel.? Kinda like "don't touch me!!"
    but no its that the tailgates just arent strong enough for that kind of force.. and its way easier to push them out of the way with your bucket then to find a chain to pull em.
    Suspect Zero, homeskillet and Bean Jr. Thank this.
  6. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,571
    Jan 23, 2016
    Eastern Iowa
    I want to get a shirt that says that
    homeskillet and tucker Thank this.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    The box is sitting on a very delicate frame protected by two large nuts to pivot on. They are protected somewhat by a Cylideral Piston system backed by it's own pump, tank and fluid system.
    The lift gate could either be a swing type hung up top by two bolts or a side opentype with a hinge on one end and a latch on other end.
    Generally these places might have a water truck but not a materials cleaning truck unless it is spocally needed device; You spill it, you shovel it. Powdered lead might come into a problem but we will cross that bridge we we get to it. (That is one item Ive always been afraid of. It theoretically can kill you pretty hard what with the pains and all)
    Dump trucks generally do not have airride systppenson so its pretty solid under there enough to whistle up a DOZER, Whicher or front end loader or even a motor grader to show up help you a smidgen. It don't take much. Even a tracked shovel can do it with a finesse you wont believe.
    Ive used my front end loader (CAT 936) model with is a relatively medium to smaller model with about a 7 yard bucket. (Manual says 6 yards, but those yankees in york did not measure southern measurements lolz) and you could get anything stuck. Used to have a competition to get a kids toy car moving out of gravel with it undamaged. (Although people still argue over my solution, about a half scoop of water and poured it towards the thing from about 10 feet. Scatters the rocks well enough without drowning model.
    88 Alpha Thanks this.
  8. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    i had the very same warnings on garbage trucks i used to drive.
    if anyone ever got stuck in the garbage (and many did), they had to be PULLED out by the garbage dump heavy equipment.
    damage to the rear dump door or hopper body can be severe.
    x1Heavy, Suspect Zero and homeskillet Thank this.
  9. nikmirbre
    nikmirbre Road Train Member
    5,544
    10,175
    Jul 27, 2011
    High Point NC
    I’ve seen “do not hump “ on railroad cars ......
  10. Puppage
    Puppage Road Train Member
    4,266
    7,381
    Aug 2, 2012
    Connecticut
    And then go stand in a long line.
    Kyle G. and homeskillet Thank this.
  11. homeskillet
    6,194
    47,376
    Jun 1, 2013
    Dayton, OH
    Yeah, always got a chuckle outta that, working for Norfolk Southern.
    It means the car has to be shoved under power to a stop; you can't just shove it over the hump (hill) in the yard, then cut it loose and gravity drop it.
    You might have already known that......Sorry.
    RockinChair, 88 Alpha and nikmirbre Thank this.
