Do Taylor Wings Work?
Discussion in 'Ask An Owner Operator' started by JLT, Nov 10, 2014.
  1. JLT
    JLT Light Load Member
    159
    55
    Feb 27, 2012
    Do these things really work to encrease fuel mileage ?
  3. Inland-Pilot
    Inland-Pilot Light Load Member
    229
    135
    Jun 23, 2010
    Jackson, Ms
    Anything that reduces drag and creates a better air flow will increase efficiency. I'd say yes to this question.
  4. Ribeye
    Ribeye Light Load Member
    151
    119
    Jan 4, 2012
    Not from my experience. On my 2000 kw w900L brick, 550 cat, 18 spd, had 86" studio sleeper, 275" whlbase. I figured it was worth a shot, so put the full sized wing on it back around 2006. I always track my mpg closely. Barely made any dent in mpg, I was always easy on the gas pedal too. Truck always averaged about 5.3 mpg, including idle time which wasn't that much. Problem is there is still too much open area around the truck and wing, so still lots of turbulence. Best bet is a full size windscreen that comes from the factory, for a brick like a pete or kw.
    Anyways, I have since got rid of it and also my last volvo 780, can't recommend that much either. Too many repairs will kill you. I'm in a new cascadia now, averaging 8.4-8.6 mpg running 59-62 mph when not in a rush, which includes idle time. Of course big payment now is a killer too. Tough business anymore. Good Luck.
  5. JLT
    159
    55
    Feb 27, 2012
    That's what I thought ribeye, thanks for the honesty!
  6. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Harrison Truck Center (Freightliner dealership) is now offering new Cascadia's as glider kits! Now that would be interesting to see.
  7. Gunner75
    Gunner75 Road Train Member
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    What is a glider kit?
  8. mrbamcclain
    mrbamcclain Light Load Member
    258
    116
    May 25, 2011
    Hammond, La
  9. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,018
    9,832
    Oct 18, 2010
    NW Indiana
    Since the Cascadia has always been equipped with post epa 2007 engines, the glider will be set up for them, even if you order it without the engine. In other words it would be prohibitively expensive to put a non emission engine in one. None of the electronic nor physical interfaces would be the same between the DD15 and the series 60.
  10. SheepDog
    SheepDog Road Train Member
    3,482
    2,084
    Nov 30, 2008
    Sand Lake, MI
    Ah,,the Glider comes without the Eng, Trans, main wire harness and, depending on what Make the truck is, a various other parts. Once the shop gets the glider, they order the wire harness for it, based on what motor they are going to put in it.
  11. 72express
    72express Bobtail Member
    18
    11
    Mar 28, 2013
    MS
    I have the full size wing. I ran it on a flat top international 9400. It helped if I was pulling a van, but pulling a flat with it on hurt me half a gallon per mile compared to pulling the flat with it off. I run a dedicated low load (4 foot tall) with the flat.
