Do you do a full Pre Trip everyday of driving?
Discussion in 'Experienced Truckers' Advice' started by hsingh_2, Dec 17, 2021.
  1. hsingh_2
    hsingh_2 Light Load Member
    81
    59
    Apr 6, 2021
    Sup drivers,
    I just have a general question regarding pre trips. I am not new to trucking but I will be sort of new to tractor trailer driving, and obviously on a tractor trailer, there are more things to check for safety.
    At the moment, I do a pre trip everyday of driving, as in checking oil, tires, leaks, etc.
    My goal is to make sure I learn all parts of the truck I will be driving.
    I see a lot of guys who don't do their pre trips, usually they just kick the steers check the trailer doors and get rollin.
    I want to actually make sure the equipment I drive is safe, especially on downgrades when loaded.
    In terms of brakes, do you get down and check slacks every single day of driving or is that something to check every few days or so?
    How do you do your pre trip? is it a full actual pre or just kick tires and go? Give me some tips on what to check for if I may be doing it wrong. All advice and tips are welcome and appreciated. Happy holidays
    Collin, bentstrider83 and austinmike Thank this.
  3. fairshake
    fairshake Road Train Member
    1,079
    1,272
    Oct 4, 2010
    Chickenville, BFE
    I call my pre trip a first pre trip, start in the morning with the basic walk around. If the truck has been sitting for a day or longer I do a more thorough inspection, during the daily drive each time I stop do some supplemental walk arounds with a slow pace. Just keep a constant check on things is easily realistic.
  4. hsingh_2
    81
    59
    Apr 6, 2021
    Good to hear. Yeah I do pretty much pre trip before driving, and after every stop or drop off, I will walk around to make sure nothing is hanging and tires are good, etc.
    I just want to make a habit of actually doing a thorough inspection for critical items like brakes, steering, etc.
    TripleSix Thanks this.
  5. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Check the lights and go most days.
    Top fluids off and give a good "thorough" look once a week. Open the hood while fueling sometimes to peek at the belts and stuff to see if they are still on there.
    But I always had newer equipment. Didn't really need to get out after starting the truck to see if an airbag inflated or whatever. If I had an older truck I would check it more but in my situation that would've been overkill....wouldn't hurt to do it still.
    One thing I always checked though no matter what is if my kingpin was locked.
    Keep doing your full pre trips. It is a great habit.
  6. hsingh_2
    81
    59
    Apr 6, 2021
    When you check things such as brakes, which I feel like is the most important thing to check, do you get down and under and check everyday or is it like every few days?
    I think as time goes on I actually learn the parts of the trucks, the pre trips won't take as long, it will be a repetitive thing which makes it more easier to look for things.
  7. Lennythedriver
    Lennythedriver Road Train Member
    2,276
    7,650
    Feb 14, 2020
    You can do it incrementally. Example, when I stop for fuel I’ll generally check everything under the hood. Including bolts, fluids, slack adjuster on front and brakes etc. what’s the point of doing that at 3 AM in the morning when it’s pitch black dark and you’re in some urine filled truckstop? But I do check it daily….Now I will get out and check the tires every single time. I’ll look underneath. I’ll check the king pin, I’ll check the hoses lights and airbags and stuff like that.
    noworrez and hsingh_2 Thank this.
  8. Chinatown
    Chinatown Road Train Member
    74,892
    170,704
    Aug 28, 2011
    Henderson, NV & Orient
    Here's how many drivers do the pre-trip:
  9. MOBee
    MOBee Road Train Member
    1,774
    10,159
    Apr 27, 2014
    Walk around at night. Full Monte in the AM. Auto slack adjusters so just an eyeball to make sure they are working. Always check the kingpin. Most drivers won't mess with your stuff, but there is always one jerk who thinks it is funny.
    hsingh_2 Thanks this.
  10. hsingh_2
    81
    59
    Apr 6, 2021
    Chinatown Thanks this.
  11. idriveaholden
    idriveaholden Super Heavy Hauler
    697
    2,192
    Mar 14, 2018
    If you don’t at least open the hood and check oil & coolant levels everyday you suck at your job
    Oxbow and beastr123 Thank this.
