Do you dump the bags everytime when pulling out from under a trailer?
Discussion in 'Experienced Truckers' Advice' started by ajsmith184, Apr 15, 2013.
  1. ajsmith184
    ajsmith184 Light Load Member
    61
    15
    Aug 13, 2010
    Howell, Michigan
    I dont claim to even be a novice driver, I simply drive from time to time for experimental/testing and our test trailers rarely come off..However, today I did drop a semi loaded trailer, and ran into some trouble..
    I got out, cranked the landing gear until it touched the ground...Disconnected the glad hands, pulled the pin...Got in and slowly drove forward...was going smooth, was out from the 5th wheel..Started to pull out the rest of the way and BAM! The trailer pin hooked the support brace on the back of the truck, damaging it slightly.
    A replacement brace is $100..not the end of the world for an engineering development truck...but I dont know what I did wrong..I guess in theory I could have dumped the bags....But ive never done that before and i didnt think most do it regularly...in face I swore during my CDL class we were told not to use it at all unless absolutely needed.
    Anyway, I like to pride myself on doing the right thing, being safe and courteous, and this caught me outta nowhere today..no big deal except a ding to my pride..J
  3. tse tse fly
    tse tse fly Bobtail Member
    yes, we have to or we catch the frame
  4. Dryver
    Dryver Road Train Member
    2,818
    2,576
    Nov 30, 2008
    Sioux Falls, SD
    It's a judgement call, it will never always be a YES or a NO. I would say if the landing gear was down properly on solid ground the trailer shouldn't drop that much after disconnecting. If I am on soft ground I am more careful about how the trailer reacts as I pull out from under it and what I do next.
    ajsmith184 Thanks this.
  5. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    you should be dumping your air bags when pulling out from under a trailer, as far as hooking to a trailer only as necessary.
    the reason for this is, you have weight on your 5th wheel your air bags are compensated by air pressure. you suddenly remove the weight ( pulling out from under the trailer) the rear of the truck will lift as it cannot bleed the air off as fast as the weight is taken off. this can lead to blowing out air bags as the bags can become over extended or in your case catching the king pin on the rear frame. so its always best to manually release the air pressure from the bags by hitting the dump switch before pulling out from under a trailer.
  6. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    This is EXACTLY why you dump your bags.
    Not only will it cost you a potential $100 brace, it CAN cost you $700+ in air bags.
  7. ajsmith184
    61
    15
    Aug 13, 2010
    Howell, Michigan
    Thanks fellas, makes total sense..Just totally confused how I got this far along, dropping and hooking this very trailer, with no issues for so long..As I said, I don't do it daily, maybe a few times a month..But still. Thanks again for the education.
  8. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Everytime. Leave landing gear a hair above the ground, disconnect everything, drive forward 1' -- dump bags, wait for trailer to settle on ground, idle forward and reinflate bags.
    Hooking is the reverse.
    Benefits: No blown air bags, no lateral load put (or left) on landing gear, you can tell if trailer is on solid ground before youre 5' away and thinking oh #### what now, minimal abbrassion on the fifth wheel surface and trailer plate from road crud in front of the kingpin, next guy that hooks won't have to lower landing gear on loaded trailer (with laterally loaded legs) to close gap, etc.
    Costs: 5 seconds
    nobrainer
    ajsmith184 and Lepton1 Thank this.
  9. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
  10. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Well put. It puts the weight down easy on the landing gear .
  11. Chris50
    Chris50 Medium Load Member
    347
    215
    Jun 21, 2010
    Florida
    My 07 Century doesnt have a switch or button to dump the bags and ive never had any issues the 1000s of times ive dropped a trailer.. Had to raise the trailer maybe 2 or 3 times ever to get under one that was too low..I always lower the gear till i start to hear air release and then just pull out slowly...
