Do you keep the air going to the trailer while being loaded?
Discussion in 'Flatbed Trucking Forum' started by A Bug, Feb 18, 2023.
  1. A Bug
    A Bug Heavy Load Member
    917
    1,862
    Mar 15, 2014
    Sevierville TN
    Not sure if it makes a difference but would that cause damage to the trailer while being loaded? I always seem to be coming up with air leaks.
  3. Long FLD
    Long FLD Road Train Member
    12,444
    51,596
    Mar 4, 2015
    Before pulling a van I always left my trailer charged so I could watch my gauges.
    D.Tibbitt Thanks this.
  4. Numb
    Numb Crusty Curmudgeon
    4,223
    9,901
    Jan 30, 2012
    Charlotte, N.Carolina
    that would mean your trailer brakes aren't on, so, no.
    Born2win and ZVar Thank this.
  5. Long FLD
    12,444
    51,596
    Mar 4, 2015
    Flatbed, livestock, pneumatic, hopper, everything except a van, the only thing I set the trailer brakes was if I was dropping it.
    Hammer166, Judge, Coover and 5 others Thank this.
  6. beastr123
    beastr123 Road Train Member
    2,916
    23,891
    Jan 2, 2014
    Moose Jaw SK CAN
    With brakes applied your gauge will not be accurate due to axle creep.
    Plus there is not enough air in the tanks to fill the suspension.
    Unless you are backed into a dock brakes are not needed for loading a flat because almost all forces are side or vertical not forward/back.
    Kyle G. and Numb Thank this.
  7. Numb
    4,223
    9,901
    Jan 30, 2012
    didn't notice it was in the flatbed section. ooops. :D
    Hammer166 Thanks this.
  8. skallagrime
    skallagrime Road Train Member
    3,850
    9,923
    Apr 10, 2012
    Indiana
    Depends on what youre loading.
    1 or 2 peices of heavy stuff, no, set brakes (realistically, need to dump air from bags, not brakes but my current trailer drops air when brakes are set though)
    Most everything else, no, leave it aired up, if backed to a dock and loading a lot of pallets its not a bad idea to drop air from trailer so as not to screw with the rubber bumpers bouncing up and down as much though
    cke Thanks this.
  9. D.Tibbitt
    152,842
    On flatbed i never set the brakes while loading... When loading to full gross weight you want to keep an eye on the air scale so you can tell then when to stop... If have brakes set you will have to wait a couple minutes for the system to come to pressure and level out.
    cke Thanks this.
  10. just_s0me_Guy
    just_s0me_Guy Bobtail Member
    49
    251
    Aug 3, 2022
    FWIW, i’ve only had sheetrock, bricks, and lumber live loaded and unloaded and never set the trailer brakes.
    no particular reason, but if i had to choose one, it helps with moving the strap rollers (not sure what they’re called) around the front axle of the trailer.
    these newer fancy metro trailers are nice though
    cke Thanks this.
  11. cke
    cke Road Train Member
    6,051
    74,543
    Aug 4, 2013
    Colfax Wi
    Strap rollers are called winches.
