Do you like Super Singles or Dually tires better ?
Discussion in 'Experienced Truckers' Advice' started by BCV, Apr 16, 2019.
  1. BCV
    BCV Light Load Member
    233
    436
    May 26, 2018
    I've ran trucks w both and it feels like the wide singles give the truck a little more stability.
    If you run them on a trailer do you think they help reduce jackknife ?
  3. PE_T
    PE_T Road Train Member
    Michelin claims their super singles provide more stability, but I couldn’t tell the difference when I drove them in 2013. Today most new trailers come with stability control. So if the trailer detects it’s about to roll over, it will instantly apply the brakes where needed to align the truck. It’s annoying at times because sometimes if I go through curves a bit fast, it will trigger the trailer auto-brake.
    To my knowledge, the fleets or people that use super singles, use them primarily for their fuel savings. I drove a T660 with super singles in 2013, and I must say the MPGs were in the 8’s. I was also driving at 55 mph.
    The main issue I have with super singles is that I fear if one blows up, it can cause an accident. Imagine going 70+ on a downhill or through a curve and having to deal with a blown tire. You can lose control, or the flying tire can hit a vehicle. Super singles make more sense for people who take very good care of their tires, and even have the tools to fix them on the road by themselves.
  4. buddyd157
    buddyd157 Road Train Member
    13,575
    34,882
    May 25, 2017
    under a shade tree
    i wish i could compare, but i only worked for companies with duals.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    I do Duals only. If confronted with a super single rig I would not drive it. We will be either replacing me as a driver or you will be putting duals on there. (Which will not happen)
    Duals is a margin of safety, there are just too many neglectful companies and drivers to risk super singles.
    mhyn, Dave_in_AZ and buddyd157 Thank this.
  6. snowwy
    snowwy Road Train Member
    20,567
    13,288
    Jul 6, 2009
    Singles have their advantages And disadvantages.
    Having a blow out would be a big disadvantage.
    misterG, mhyn, x1Heavy and 1 other person Thank this.
  7. JamesMorgan
    JamesMorgan Bobtail Member
    4
    Apr 4, 2019
    singles for owners, doubles for companies..
  8. Tb0n3
    Tb0n3 Road Train Member
    4,607
    9,252
    Oct 5, 2012
    Earth
    Why must you continue to write in the present tense. You'd get a lot less flack if you just started using past tense when referring to driving.
    homeskillet and Milr72 Thank this.
  9. againstthewind
    againstthewind Road Train Member
    2,027
    3,164
    Oct 26, 2012
    after driving a truck with super singles theres no way i would put them on a truck im paying for. but i appreciate the guys who do have them that have a blow out leaving a bigger piece of rubber in the road, im glad your saving money as i try to dodge a blown out super single lol also the guy changing the tire says thanks, his back needs a workout lol
  10. rcelmo
    rcelmo Medium Load Member
    459
    1,986
    Mar 23, 2015
    Super singles on trailer.....yes
    Super singles on tractor......absolutely not
  11. Diesel Dave
    8,798
    25,604
    Jan 20, 2010
    Hesperia, Ca.
    Wrong .......
    JoeyJunk, Brettj3876 and mhyn Thank this.
