Do you lock your differential in while driving in snow with chains on?
Discussion in 'Experienced Truckers' Advice' started by YOUNGSTER, Oct 1, 2018.
  1. YOUNGSTER
    YOUNGSTER Light Load Member
    69
    11
    Aug 6, 2010
    Sacramento, CA
    I run in California and we run over donner summit on 80 and highway 50 into South Lake Tahoe a lot. We have pretty strict chain laws In comparison to other states.
    I have been told by some drivers that with the differential locked in the truck does not want to turn correctly while in the snow and I shouldn’t need to Lock it in when I’m fully chained up. 6-8 chains on a semi. Any advice or experience with driving in snow with chains?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Some trucks do not know how to run right or left. They might try it for you but you are going to be a little rough about the circle or understeer etc.
    Interlock is there to keep it moving in conditions that will cause a normal drive pair to refuse traction. Just never use it on dry pavement, you will burn it up.
  4. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    I had the inter locked at 98 mph before. No problem.
    Dont tell anyone, ok thanks.
    Disclaimer anything I say may contain up to 95% truth.
    tscottme, KB3MMX and Western flyer Thank this.
  5. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    The truck wanting to go straight usually will happen going slow on the back roads in a tight turn and you have some throttle in it. If you let off the throttle they will unlock briefly/temprarily for the turn. It is a good idea to know about it and be expecting it.
    I don't think you will see it happen going up Donner. Maybe if the 5th wheel was dry and sticky it would happen more often. Climbing Donner would be a good time to try it out and see what happens. Maybe give it some throttle when you go into a tighter turn to see how it handles.
  6. Oldironfan
    5,776
    5,544
    May 22, 2017
    The key is not engaging the inter lock over 55mph.
    skellr Thanks this.
  7. skellr
    8,735
    12,187
    Jul 17, 2011
    I wouldn't use them over 45-55, especially on ice. Suicide.
  8. Oldironfan
    5,776
    5,544
    May 22, 2017
    Unless chains are used.
  9. AModelCat
    161,680
    With the interaxle locked your diffs still allow wheel speed variances between the left and right. It will affect the steering but not nearly as much as locking in the axle locks.
    KB3MMX Thanks this.
  10. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    20 yrs running the rockies in the winter, chaining multiple times, never once used interlock or power divider in addition to chains
  11. okiedokie
    okiedokie Road Train Member
    13,415
    104,741
    Jun 13, 2011
    PNWET
    I'm not touching this one. oy vey
    snowwy, 201, not4hire and 2 others Thank this.
