Do you really need to go 102" ?
Discussion in 'Ask An Owner Operator' started by LittleMissCabover, Jan 26, 2014.
Depends on where you're running but I'd guess that it wouldn't be well received by a lot of shippers, especially those that like to place two pallets sideways rather than pinwheeling them.
Then again, it may not matter at all. Really depends on the shipper.LittleMissCabover Thanks this. -
Yes a 96" trailer would hurt getting loads if your working a load board.
If you have a specific type customer maybe not.LittleMissCabover Thanks this. -
102" has been the standard for well over a decade now, there are tons of cheap vans out there, literally 6-8 grand will get you a good trailer that will need a minimal amount of work.
Why at that price point settle for a 96" that will cut into your profits?truckon, LittleMissCabover, lovesthedrive and 1 other person Thank this. -
A driver I know bought a 53' 102" for 2 grand and has been using it for several years with no problems. He bought it at a farm equipment auction. Yes, get a 53/102. Make sure it's a swing door & not a rollup because some companies such as paper product companies won't load a rollup door because the loaded pallets are too tall and downstacking is not allowed.
LittleMissCabover and jldilley Thank this. -
being a flatbedder who hauls a lot of pallet loads. that extra 6 inches makes a BIG difference.
It is getting difficult to even find a 96" wide trailer. And comments above are right on about needing a 102" to get loaded. That is the standard.
A 96 will get you better mpg. I think a 12'6" x 96" x 48' spread axle would be the best. Unfortunately the mobile warehouse industry doesn't agree.
Almost every load I haul would fit in a trailer with those dimensions. But if you ask the broker they typically only know what their computer says which is often limited to the commodity, the weight and it needs a 53' trailer. So like everyone else already said...you need a 53/102 or you won't even get the load.LittleMissCabover Thanks this.
Just tell them you have a 53/102. You can even stencil those numbers inside the door on the plywood to trick any forklift drivers who might throw a wrench in your spokes for having the wrong size.
281ric Thanks this.
