Does anyone have a 2000 FLD120 with the 12.7 Detroit?
Discussion in 'Ask An Owner Operator' started by ApeHangerGod, May 16, 2021.
  1. ApeHangerGod
    ApeHangerGod Bobtail Member
    25
    14
    Aug 28, 2018
    As stated in the title, Does anyone have one? I bought one that doesn't have a windshield washer reservoir. I want to put on on it, but I'm not sure where they are suppose to go on the 2000 FLD120's. Does anyone have any pictures of placement for me to use as a guide?
    singlescrewshaker Thanks this.
  3. 062
    062 Road Train Member
    6,231
    33,514
    Oct 20, 2013
    6,231
    33,514
    Oct 20, 2013
    Now that I thunk on it, I seem to remember it was in the right side box of the one I had.
    @jamespmack
  5. singlescrewshaker
    4,851
    42,377
    Dec 31, 2017
    Little Havana, FL
    Well mine's a '93 model, & uses air for the squirter..
    Works on occasion.. :rolleyes:
    But here it is.
    In the driver side box under the bunk, forward wall..
  6. singlescrewshaker
    4,851
    42,377
    Dec 31, 2017
    Little Havana, FL
    Old Jimmy eff'n 2 Lane has a y2k!!
    Why didn't I think of that & pass the buck to him.. lol :D
    Rideandrepair, jamespmack and 062 Thank this.
  7. Long FLD
    Long FLD Road Train Member
    11,988
    49,382
    Mar 4, 2015
    Pretty sure my ‘03 was in the side box on the driver side but I can’t remember for sure. It would blow the fuse for the pump all the time so I ended up just filling it in case I got inspected and not using it.
  8. jamespmack
    215,910
    That were mine is located. The thinner bottle. I can get a pic Monday.
    Day cab its behind passenger seat.
  9. Dino soar
    Dino soar Road Train Member
    4,791
    26,882
    Dec 8, 2017
    Mine is a 95 and it is in the driver side box.
  10. Rideandrepair
    17,355
    56,303
    Aug 8, 2015
    They go in the side box. Have to lift up bunk to fill it. It’s mounted on the front wooden panel, behind drivers seat.The motor is near the bottom, on the side of tank. Liquid rubber line goes through floor, to firewall. Should already be a small hole in bottom of Cab, if not should be a larger hole, with a plug on it. you use can it by drilling a small hole through the plastic plug.
    singlescrewshaker and Dino soar Thank this.
  11. zinita17601
    zinita17601 Road Train Member
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    I own one,its on the driver side,if you look under the rubber cone(dont know the proper name)that hold the hood in place you will c enough room to mount the tank on the firewall.
    Its also visible if you look up from fuel tank.
    Rideandrepair Thanks this.
  12. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    What a crappy spot for one. My uncle's classic is like that. All that room under the hood and they put it in the side boxo_O
