Does anyone know..... (2019 Freightliner )
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Commuter69, Dec 30, 2020.
  1. Commuter69
    Commuter69 Road Train Member
    1,137
    632
    Jul 2, 2014
    I am not a mechanic, nor do I play one on TV......
    I have this fault and I am not sure what it means, what causes it, or what could happen if it isn't dealt with or otherwise turns off....
    Just don't want it to escalate into a road call issue.
  3. AModelCat
    159,398
    My guess is the axle temperature sensor wiring is damaged. They hang out in the open. Not out of the realm of possibility that a rock hit the sensor or something like that.
    magoo68 Thanks this.
  4. Commuter69
    1,137
    632
    Jul 2, 2014
    Would it be obvious to the layperson in daylight to see?
  5. AModelCat
    159,398
    Sometimes wiring damage is pretty obvious, other times not. Can't hurt to look at what wiring you can see as well as at the sensor. Sensors are usually threaded into the axle housing in the middle section, on the lower portion of the housing.
  6. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Mine has been like that since first trip through the snow. 50K later it is still like that front one works so I just ignore it. Wrench told me it is the sensor or a broken wire not a problem
