Does anyone run a small external AC/heater unit?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by JChors, Jul 21, 2015.
  1. JChors
    JChors Medium Load Member
    333
    237
    Apr 20, 2009
    Newport, OR
    I've been doing a bit of internet surfing to find a small, quiet unit that would heat and cool the cab of my pickup using a small generator. It needs to be compact and somewhat affordable too. I came across this one online:
    http://www.climaterightair.com/products/climateright-2500-btu-mini-ac-heater.html
    It checks all my requirement boxes. It heats/cools up to 400cu ft. My cab is less than half that. Runs at a 4.3 amp draw (air) so my Yami inverter genny will handle it no problem. It plumbs thru the back of the cab instead of being roof-mounted, so it's less exposed to the elements, and can be hidden from prying eyes.
    I know it says it's not warranteed for R.V's, trailers, and trucks even as they recommend it for teardrop trailers! Has anyone used this unit, or have another setup that would work? Pics if you have them.
  3. Lite bug
    Lite bug Road Train Member
    1,412
    33,664
    May 3, 2014
    Columbus Ohio
    Neat looking setup. I seen similar unit on another hotshot forum. I run a portable a/c unit off my generator, I have to vent the hot air out and looks unusual from the outside. What you are looking at is a clean and finished look. The question I have is would the hoses stay intact while driving all day, or the vibritation affect it.
  4. JChors
    333
    237
    Apr 20, 2009
    Newport, OR
    It's a portable unit so i think it's inyended to be disconnected and stowed away when not in use. I actually like the quick disconnects, and i like the clean look of requiring just two small holes to the cab.
  5. Lite bug
    1,412
    33,664
    May 3, 2014
    Columbus Ohio
    Yelp, right about that. So you are using it?
  6. JChors
    333
    237
    Apr 20, 2009
    Newport, OR
    No. I want to see what other drivers are using before i pull the trigger.
  7. flatbedcarrier
    flatbedcarrier Medium Load Member
    667
    826
    Jun 8, 2005
    Southern California
    Have had guys try a few different A/C units over the years. What happens in most cases is the vibration and impact from the road usually causes the lines inside to crack. I think if a rack with some type of suspension, springs, or soft rubber mounts was made for the A/C unit to ride on, those lines would be less likely to crack?
  8. JChors
    333
    237
    Apr 20, 2009
    Newport, OR
    Sounds about right. It's definately a concern when the unit costs five times ($500) what a basic window mount unit costs. Maybe the R.V. rooftop units are better designed to take the road vibration but i havent found one small enough for what i need.
