Does Class B Passenger bus experience help me towards my goal of Class B straight/dump truck?
Discussion in 'Questions From New Drivers' started by Cyb3rst0rm, Sep 18, 2025.
  1. Cyb3rst0rm
    Cyb3rst0rm Bobtail Member
    14
    36
    Mar 27, 2025
    So I got fed up with working for Schneider after they asked me to do a number of sketchy things, kept getting me home late, giving me worse and worse loads (despite me being on time and generally not causing problems).
    My plan with a CDL was never really to do tractor-trailer combination work, but to drive a dump truck or similar (there are a ton of quarries and coal mines and stuff near me) but for some reason it seems like Class B local work legit requires more experience than Class A. Most Class A jobs are asking for 6 months to a year minimum, Class B are all telling me 2 years experience. Several of them have told me its an insurance requirement.
    As of right now I've secured a job offer from a local public transit. Pay is acceptable, but my question is will class B experience driving a bus count for insurance/experience purposes towards my goals here? Like should I stay with this company for a few years or keep looking for something more strictly in the trucking industry vs just the CDL industry.
    nextgentrucker Thanks this.
  3. nextgentrucker
    nextgentrucker Road Train Member
    1,529
    1,349
    Sep 25, 2023
    Port Saint Lucie, Fl
    Can't you just get a Class B job with a Class A license? I thought you could, guess I was wrong.
    OldeSkool Thanks this.
  4. TripleSix
    132,260
    Those class A jobs you’re looking at are still training companies that are self insured. The companies that can actually get insured will have a completely different set of requirements.
    OldeSkool and brian991219 Thank this.
  5. Ridgeline
    22,609
    120,101
    First, it isn't about class B or A, it is what the truck is.
    AND it isn't all about insurance; it is about experience.
    Watch these drivers work; there is a skill needed to put the load right where the customer wants it or to follow instructions and put the truck where it needs to be.
    Most semi truck drivers don't need to think much, and seeing 99% are steering wheel holders, 6 months is all that is needed.
  6. brian991219
    brian991219 Road Train Member
    2,999
    6,091
    Aug 10, 2013
    Lords Valley, PA
    No, the bus experience will not transfer into dump trucks or other vocational type work. Speaking from direct experience, since I began my career at 18 as a school bus mechanic and driver, then moved into commuter bus, they are far too different of jobs.
    Dump trucks are a unique animal with overhead obstructions and tip over hazards being critical. Most employers don't want to be the first dump truck you drive to be theirs, too easy to roll it over or hit something, and they really don't care at all about tractor trailer experience unless you were doing open deck or hauling heavy equipment. My dad and brother owned an asphalt paving company, so I got a lot of dump truck experience in addition to my bus experience, and can tell you they are very different jobs.
    It is easier to transition into dump trucks if you do other vocational type work first, such as fuel oil or propane delivery or get on with a big construction company and drive one of their flatbed material trucks or use your class A to haul around equipment for them. Once they see that you are a good driver that can handle being off pavement, makes good decisions, can work independently and are willing to do the manual labor required, they will likely consider putting you into a dump truck or cement mixer.
    tscottme, nextgentrucker and TripleSix Thank this.
  7. Cyb3rst0rm
    14
    36
    Mar 27, 2025
    I'm looking for paths to experience that don't involve being a slave working 70 hours a week OTR away from home 5 days at a time for substandard pay. Having done some OTR now and seeing the time commitment it involves (it really basically has to become your lifestyle) and the amount of potential liabilities you shoulder as the CMV operator (IE: civil suits if there is a wreck even if its not your fault, DOT violations if you slip up and miss something) the pay in OTR is absolutely laughable. Anyone that thinks it should be legal to work a human being 70 hours a week, and ask them to be away from the comforts of home (even just the basic comforts, like a daily shower) for a week or weeks at a time and pay them less than $100k a year regardless of experience is a ####ing moron. Every driver should be paid hourly, with overtime mandatory at the same hour points as other workers. I'm sure the right wing gigabrains on here will call me a commie or some #### for suggesting people get paid fairly.
    It seems like bus driving and garbage trucks are the only ones that consistently hire without a ton of experience. Garbage actually pays a bit more, interestingly but they all want to start you out being a helper that jumps out of the truck 100 times an hour. ILDOT hires snow-plow operators but they need an X endorsment (I'm guessing road salt is hazmat, and since they use liquid sprayers you need tanker) and I haven't had a chance to get tanker or hazmat added to my license yet (I really probably need to prioritize getting the rest of my endorsements). Fuel oil, propane delivery, etc around me all want at least a year experience which I at least understand that given they are hauling highly flammable/explosive materials.
    Also what manual labour is involved driving a dump truck? I see them constantly around me and they are all being driven by old fat dudes. I'm sure GOAL applies (probably even more often than it does in dry-van, considering as you said product placement becomes important) but what else? Like I'm not doubting you, I'm just curious what part of the operation I must not be thinking about here. I assume dump trucks are loaded by other heavy equipment, and the dump bed itself is hydraulic obviously.
  8. brian991219
    2,999
    6,091
    Aug 10, 2013
    Lords Valley, PA
    As for manual labor with dump truck gigs, most entry level dump truck drivers also do labor on the job site when there is nothing to haul unless you get hired onto a union or union scale job. So it is reasonable to expect to be shoveling material after it is dumped to help spread it out, helping move tools and equipment around and other labor tasks. On our paving crews the dump truck driver would often help rake the edges, tamp the tight spots and clean up after the last load of asphalt was hauled. Then they would help load up the equipment and chain it down on the trailers to move it to the next jobsite. Same on our pipeline/waterline crews, there was always manual labor to do in-between loads to haul.
    Also, depending on the product you may be climbing into the dump body with a shovel to dislodge stuck material. Think about asphalt as it cools down or heavy clay soils that clump in the corners of the body. If that stuff clumps up it can build up enough to become dangerous, causing a tip over condition when you try dumping. Even if not dangerous, it reduces your hauling capacity and is frowned upon.
    Yes, dump truck driving is mostly no touch, just drive, once you have paid your dues and get in with a good company but an entry level job will likely include labor and even some days where you are asked to run a loader or other machine instead of driving. One bonus for you, since you have a class A, a good construction company may be interested in you if you are willing to learn how to operate machines and load them on the trailer to move them from job to job. That is very valuable, especially for smaller construction companies or specialized crews like asphalt or water/sewer line construction or even municipal government road crew jobs.
    Now, something to think about with dump truck jobs, unless you are in a fair weather state they are seasonal. You will need to be prepared to be laid off for several months each year, so the hourly pay rate really is not as good as it seems unless you have a second job for the off-season. Many dump truck drivers I know will do the seasonal or casual plowing for the state in the winter, or deliver fuel/propane, so they have year round income. You mention Illinois DOT, so I presume you are in IL, which probably doesn't have that many year-round dump truck jobs.
    Nothing worthwhile comes free, we all must be willing to earn our place in life, including the luxury of having a somewhat easy time at work. Do yourself a favor and get your tank and hazmat endorsements. It will really help open up your vocational driving job opportunities.
    tscottme Thanks this.
  9. tscottme
    tscottme Road Train Member
    I read the OP's post twice, and parts of it 4 times. Hey OP what is your goal? Describe the job and the vehicle in your answer and not how employees ought to be treated and goals for humanity, if that's possible. A helpful answer would be like "I want to drive dump trucks M-F and understand that means winters will be slow." Or another example could be "I want to drive a sleeper truck but only 5 days a week." Something like that which indicates your goal to do Class A or B, what type of truck, and so on.
    The jobs you don't like and consider an insult or their pay is insulting are working well for some people in some places and it only matters what that employee thinks about his job. Some people make decisions you won't make and you'll need to learn to carry on as if you are not in charge of their life's decisions. It may delay the Revolution's fulfillment. So be it.
    snicrep Thanks this.
  10. Cyb3rst0rm
    14
    36
    Mar 27, 2025
    Home daily, left to my own devices to deliver cargo from point A to point B (and any additional points).
    No boss breathing down my neck, no dealing with the general public (that's basically the one downside to driving a bus), minimal manual labour.
    I don't really care if that ends up being Class A or Class B or the equipment type. I just want as close to a pure local driving job as reasonably exists. That's basically what I had before I made the mistake of quitting my previous job to get a CDL. I was driving a cargo van, making 6-8 stops a day unloading a couple crates of auto parts at each stop then driving an hour to the next store. I got my CDL thinking I'd drive a dump truck or a rock/coal hopper (again, lots of quarries near me).
    The problem I'm running into (and this is a sentiment I've seen here and several other places, from multiple people) is that it seems your expected to spend your 20s doing back breaking work that destroys your body before you get such a job. My body is already destroyed at 25, and I don't expect it to improve at this point (I've given up on weight loss). I physically can't do it. Even doing dry-van for 3 months my back and joint problems are noticeably worse, I figure I've got 5~ years before I can't even do that stuff anymore so I need to get my experience in now so I can find a true no touch, minimal leaving the cab job by then. I fully expect to be dead by the time I'm 40 so I'm not even planning beyond that.
  11. OldeSkool
    OldeSkool Road Train Member
    1,874
    5,780
    Jul 17, 2018
    New Hampshire
    You need to get a job hauling wood chips from the sawmill to paper mills. I did that for years. It’s local work without much manual labor. You’re basically left alone as long as you do your job. It’s class A tractor trailer work.
