Does Cruise Control Save Fuel or Use More Fuel?
Discussion in 'Experienced Truckers' Advice' started by EZX1100, Dec 24, 2012.
  1. EZX1100
    EZX1100 Road Train Member
    4,017
    5,711
    Aug 18, 2012
    Virtually everyone i speak to says they drive with cruise control on. They say it saves fuel (set at 65 or 62)
    i tried that a few times, and it seems i use more fuel.
    Anyone else compare the two?
  3. jgremlin
    jgremlin Heavy Load Member
    867
    497
    Apr 21, 2010
    SW Michigan
    Try it more than a few times.
  4. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    its sort of like whats better a chevy or a ford. answer depends on who you ask
  5. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    IMO Depends a lot on the terrain. Flat land it can driving thru the hills not so much.
    Drachen Thanks this.
  6. EZX1100
    4,017
    5,711
    Aug 18, 2012
    it shouldnt be a subjective answer, no?
    i swear, whenever i use cruise control, when it wants to catch up to speed, it uses more fuel (further accelerator depression) that i would use
  7. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    I think it's to aggressive for the hills. I don't want to crest a hill at 100% throttle when gravity is waiting on the other side. waste of fuel.
    Rick_C and EZX1100 Thank this.
  8. skellr
    8,737
    12,184
    Jul 17, 2011
    There has to be a way to tweak that setting.
  9. jgremlin
    867
    497
    Apr 21, 2010
    SW Michigan
    But that's an anecdotal assessment not a scientific one. If you want to know the true answer, you need to do what I said above, try it more than a few times. Run for a month or better yet, two months or three (the more the better) with no cruise control. Then divide miles driven in that time by fuel used. Then drive the same amount of months using cruise control as much as possible. Divide miles driven by fuel used and compare the results. Then you'll have a better answer.
  10. pokerhound67
    pokerhound67 Heavy Load Member
    801
    665
    Oct 30, 2012
    one truck, or even a few trucks, is STILL an anecdotal assessment, even if you did it for a few months, or even throughout the life of the engine. to know the true answer, youd need a much more scientific study than one or a few guys observing results in their own trucks. so, yes, all you will get by asking on a forum like this is going to be a subjective answer.
  11. TripleSix
    128,101
    For me, its not fuel...its staying out of trouble. But since you are asking about fuel economy, I would say that it would depend on how a truck is set up. Most factory setups have the 'soft cruise' setup. Without soft cruise, going uphill feels like you're about to have one of those Toyota moments where the throttle gets stuck at WOT. If you have the cruise set on 65, it hits 100% of HP until you reach 65. On foot, you wouldnt do 100% once you got near 65. Youre at 64mph and shes still at WOT, and you wonder, "Is she going stop at 65???" So, in a 65 mph truck with soft cruise engaged, I would say that you really shouldnt be able to see much difference.
    Now, if you are in a faster truck and about to hit the hills, I would put the throttle down a bit to spool the turbo. See cruise doesnt kick in until you drop several MPH. And the turbo has to spool up and start boosting. You lose alot of momentum waiting on the cruise to kick in. When the turbo kicks in, youre at WOT without momentum. Even if you were running 65 on cruise, its better to put the throttle down a bit, kick up the speed to about 70-72, get the turbo spooled and use the extra momentum to top the hill. Better fuel economy and easier on the engine and driver.
    EZX1100 Thanks this.
