Does DOT allow for fuel weight
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, Jan 27, 2017.
  1. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    193
    60
    Apr 13, 2016
    I've read on this post that more times than not you won't get stopped for being a little over but the only way to be sure you won't get stopped is to be under the axle weight limit.
    I'd rather not risk it.
    Which states do you think might be more strict about being over on the steers (i will not go over 12,500 pounds)
  3. Jdm5jdm5
    193
    60
    Apr 13, 2016
    I'm not 100℅ but I'm pretty sure the fuel tanks are 100 gallons on each side. It's a 2015 cascadia freightliner.
    No I don't have an APU
  4. mjd4277
    mjd4277 Road Train Member
    14,771
    45,597
    Oct 4, 2015
    Fitchburg,MA
    Slide the trailer tandems back(if possible if should be able to get at least 32,900 pounds on the drives if the trailer was loaded properly (max limit is 34,000 pounds but 32,900is ideal for helping balance out the truck taking into consideration the need to refuel at some point ).
    Jdm5jdm5 Thanks this.
  5. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
  6. Jubal3
    Jubal3 Heavy Load Member
    878
    950
    Apr 2, 2015
    Central WA
    Never EVER roll over 80k (assuming you're standard). DOT will usually allow you to fix axle weight. Over gross, it's a $1000 ticket. I will spend many hours before I risk $1k of MY money for someone else's freight.
    Cw5110, Jdm5jdm5 and mjd4277 Thank this.
  7. KMac
    KMac Road Train Member
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    Just got one myself on Thursday... It's a not a moving violation so no problem on the MVR
    Jdm5jdm5 and scottied67 Thank this.
  8. Bean Jr.
    Bean Jr. Road Train Member
    5,575
    9,937
    Mar 30, 2014
    I will say it one more time. The max allowed on the front axle is not the difference between 80,000 lb and 68,000 lbs. It is the lowest between 20,000 for a single axle, the axle rating and the tire rating. Those states that allow less than 20,000 only state that the assumed axle rating is 12,000 unless proof to the contrary, if the tag is missing on the axle, or the stickers inside the door are not clear about the weights, then that state will only allow 12,000 lbs.
    As for sliding the trailer tandems back to put more weight on the drives, that will also put more on the steer axle. Sliding the tandems shifts the weight to and from the the tandems from and to the fifth wheel. Sliding the fifth wheel shifts the weight that is on the fifth wheel between the steer and drive axles. Put more on the fifth wheel, more on both steers and drives.
    One more time, unless your steer axle is not rated higher than 12,000 lbs, and your steer tires are not rated at least 6,150 lbs, Rolling 12,300 is not hoping for no trouble, it IS legal.
    Jdm5jdm5, not4hire and scottied67 Thank this.
  9. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    *20,000 for all interstate routes
    Steer axle weight is becoming the new dead horse ....
  10. mjd4277
    14,771
    45,597
    Oct 4, 2015
    Fitchburg,MA
    This one has variables. It may put more weight on the steers but it shouldn't be that dramatic of a weight change if it's done properly. Another thing to consider is how the fuel tanks are mounted on the truck and if the fifth wheel is adjustable. Food for thought.
  11. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Simple math
    Steer axle = A
    Drives = B
    Tandems = C
    If A+B= 46000+ you may have to move tandems closer to drives
    If B+C=68000+ you must move tandems away from drives
    *assumes 34000 limit for drives and tandems
    Adjust 5th wheel to balance A and B but their total will not change much, only the distribution of weight.
