So every once in a while you read in Trucker Path comments reporting bad fuel because they got low MPGs. But has anyone really been able to verify these claims? I can see how dirty fuel can lower MPGs, but what about fuel that isn’t dirty, just not “high quality” fuel. I have a good feeling most of the folks saying these things haven’t eliminated other factors that lower MPGs such as terrain, wind speed, cold temperature, load weight, speed, etc.
Does Fuel Quality Affect MPGs?
Discussion in 'Ask An Owner Operator' started by PE_T, Nov 18, 2018.
Page 1 of 4
It's all the same to me. I guess one could argue winter fuel is "lower quality".... then again, it will run at colder temperatures. This is especially true up here in Canada. The winter blend will cost you about 1 mpg. But no additives needed. Your #2 without additives may experience fuel gel up way before our pump fuel will.
Some people say petro has best fuel. Or ta. Or loves. I've burned them all. It all comes from the same ground, probably the same refinery. If you believe some fuel station saying they use some additive to give better mpg consider this scientific question: just how, exactly, do you increase the energy content of 1 unit of fuel? Answer: you don't!Sirscrapntruckalot, MartinFromBC, adayrider and 1 other person Thank this. -
Before the merger Flying j owned thier refineries. Don' no how or why, but thier fuel ALWAYS gave me the best mileage. But nowadays I think I get the same mpg from everybody. Of course depending on what the content count of bio fuel is. No I don't no why and can't explain. But i no tank after tank the numbers show me over and over
PE_T Thanks this. -
I mean a higher quality fuel usually burns more efficiently so I suppose the argument could be made that you might get better milage on the better fuel because your engine doesn't have to work as hard.
In town I fill up at sheetz rather than exon or the other ones. And the reason being when Hurricane Matthew came through back in 2016 and flooded the area out, the exon in town was caught selling contaiminated fuel and it blew a few engines. Lesson here boys and girls: when the flood waters wash out the sewage treatment station and washes poop water and puts a gas station underneath said sewage water, ya might not trust the gas. Besides, I get more bang for my buck with sheetz.
But as far as the mpg thing, can't say I've ever noticed a difference.Sirscrapntruckalot and PE_T Thank this. -
"Sheetz gas- without sheet water"
ElijahJohn1 Thanks this. -
What's the Deal with Winter Diesel Fuel? - NW FuelPE_T Thanks this. -
There was a fuel dealer in Maryland capable (Note I said capable..) of selling leaded gasoline for off road use only. And you can get it via Avgas today, however I think 2018 is the last year you see it in use because of FAA combined with a declining percentage of airplanes using it (Private planes like 172 only) you have what is called mo gas and a conversion called Impulse for small planes to run on ethanol fuel.
If you were eve caught with leaded gasoline in a older car on public roads the fines were big time. 5 figures.PE_T Thanks this. -
Yes, fuel from some places is better. Engine has more power, working quieter. I use mostly PFJ so it depends on supplier in this area.
Page 1 of 4
