Does my truck have a power inverter?
Discussion in 'Ask An Owner Operator' started by Leosmel, Feb 23, 2018.
  1. Leosmel
    Leosmel Bobtail Member
    Guelph, Ontario, Canada
    Hello friends,
    How do I find out whether my 2015 Cascadia has a power inverter?
    If it means anything, it came with a fridge when I bought it. 1519374203806663218254.jpg
    Thank you for your help with this.
    Lee
  3. FLCRACKER
    FLCRACKER Medium Load Member
    344
    203
    Oct 11, 2013
    Lorida, FL
    Look around sleeper for outlets or under your bunk it may be there. Will be a box looking thing with outlets. The fridge is 12volt doesn't nee an inverter.
    Leosmel Thanks this.
  4. Leosmel
    Thanks for the info ☺️
    Unfortunately, I ddon' have an inverter. Will need to invest in one.
    I appreciate your taking the time to reply
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    Refrigerators Refrigeration | Dometic
    I cannot identify your exact model.
    Some products on that page requires liquid Propane gas which is DEFINATELY A NO NO around a big truck and some require 120 volt AC power at 60 american hertz (Lucky for you, if it was 50 or something else you would have to go international and get it... 220 volts etc)
    Some DO have 12 volt connector. Put those into a big 12 volt tube plug kept nearby for things like lighting up cigars or something. You should have two up front in the cab ahead of the shifter.
    If you install a inverter do it at a dealership, WITH SPECIFIC and EXPLICT permission from the Officers of your company. Because that truck might not be a bought truck, but leased, rented or some other arrnagement that will complicate things should a unauthorized inverter catch fire and burn it all down.
    In today's world of mega stop idle and drain batteries really quickly... no start etc having to run a inverter to feed your frozen food in a truck like that is impossible. You would do better hunting Ice in a cooler strapped to your catwalk.
    We just used a standard camping vehicle cooler stuck into the freightliner\s cabinet with a giant 12 volt plug on it. It did have a 120 volt, but we never used it to be honest even though we had a inverter for it. We were very careful about using that thing. Food like Bacon is gone long before it has a chance to turn bad in a small reefer like that.
  6. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Get at least 2000 watt
    5000 watt is better
  7. Ridgeline
    22,461
    117,733
    That's a 12 volt "truck" fridge using a swing compressor.
    If you get an inverter, please please have a professional install it.
    Don't try to do it yourself.
    Make sure you ask that it is fused at the battery and PLEASE buy a good one that is a pure sine wave inverter. NOT some Chinese junk.
    Tb0n3 and CorsairFanboy Thank this.
  8. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    Yes I agree, a red and black wire are too difficult for some drivers to handle.
    Old-school trucker Thanks this.
  9. Tb0n3
    Tb0n3 Road Train Member
    4,634
    9,327
    Oct 5, 2012
    Earth
    Most inverters are modified sine wave and run almost everything just fine. If you want to spend the money to get a pure sine wave then by all means, just understand that it is by no means required.
    Power Inverters - The Inverter Store - Your Complete Inverter Source
  10. nightgunner
    nightgunner Road Train Member
    2,112
    2,800
    Jul 23, 2013
    Cedar Rapids, IA
    I have a 3kw pure sinewave Coleman inverter. Picked it up at a pawn shop for $100. The thing is huge, but does a great job.
  11. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    did you have a professional install it?
